Hot Bodies D413 1/10 4WD Buggy
#6827
Don't you guys think that if you have shim the diff, change the pinion gear and done everything possible to the buggy, it might just be a bit louder than normal buggy, it does have all metal gears so if you are comparing it to another buggy it's not a good comparison since I think AE & Losi are plastic gears and belts, and besides as long as I'm in the podium positions the buggy could sound like a cow for all I care. Lol
#6829
#6830
Gear diff cars are much louder than ball diff cars... Ae car sounds similar and it has similar metal gear diffs. TLR car on the other hand is virtually silent. I own all 3 and the HB car is pretty darn good.
#6831
R/C Tech Elite Member
I vote: "Who cares?"
#6834
Hey guys. I picked up a used D413 and I'm hoping to have it running this weekend. I'm just waiting on electronics so I can run back to back with my DEX410V4.
My question is...how many suspension arm mounts come in the kit and which ones? The only mounts I have are the ones on the car now.
#6835
#6837
thanks
#6839
I read a while back that guys were breaking off the tiny thread end of the hinge pins and it's happened to me on a front one. There was a little bit still sticking out of the nut, so I was able to remove it, which means it wasn't all the way tightened when it broke off. Just wondering, are you just ordering a new one or is there another fix? As much as I hate c-clips, I'd rather go that route. Is there a hinge pin or shock shaft from another car that will work? I'm just finishing the wiring and it's going to be a drag not to be able to try it out just because of this. LMK
#6840
