Hot Bodies D413 1/10 4WD Buggy
#4967
i went with 3x1.3 piston so i could run thinner oil and for obvious other reasons.
#4968
I also thought have 2 x 1.6 and 2 x 1.7 was too soft. I finally settled on 3 x 1.3 all around with 37.5 in the front and 32.5 in the back. I am happy with the front but the back is still a little soft. Might try 35 or am tempted to go 2 x 1.6 or 2 x 1.5 in the rear.
But so far the 3 holes are good and seem to work well in various conditions, med to med-high traction.
#4969
#4970
Anyway, I took the 4 x 1.3 and plugged up a hole. Since even Torrance said that was a way to do it, I thought I would give it a try. I plugged the hole with a tooth pick, glued it in, and dremeled it pretty much flush to the piston. I recently changed shock caps so I got a chance to check on them and the hole is still plugged.
#4971
anyone using something like this with the AE caps to help seal them?
http://www.amain.com/Kyosho-Big-Bore...-Set-4/p193568
#4973
just so you guys know...Ty told me the reedy set up was way easier to drive.
#4976
Is most everyone running the Black rear sway? I am running silver on a bumpy high bite track. This is on my list of things to try this weekend. Also, what is the difference with the Dot suspension pieces for kick/squat? The setup sheets list 2x ways to get 11deg kick? Is one LRC vs HRC?
#4977
Team Tekin
#4979
http://www.petitrc.com/setup/hotbodi...413_Charts.pdf
#4980
