Hot Bodies D413 1/10 4WD Buggy >
Like Tree66Likes
Old 07-28-2014, 01:45 PM
  #3886
Trader Rating: 22 (100%+)
If any body is interested I have front a arms and ball cups for sale. $10 takes them
masin14 is offline
Old 07-28-2014, 02:57 PM
  #3887
Stevomatik's Avatar
Originally Posted by yzracer758
TLR makes the 2x1.6 and 2x1.7 pistons.
I don't think the tlr pistons fit because the center hole is too big... I have some and I tried to make them work... I ended up just drilling my own 2 hole
Stevomatik is offline
Old 07-28-2014, 03:36 PM
  #3888
Team Tekin
yzracer758's Avatar
Trader Rating: 18 (100%+)
We got 3 D413's running TLR pistons with no issues
yzracer758 is offline
Old 07-28-2014, 03:58 PM
  #3889
tazfam2's Avatar
Trader Rating: 54 (100%+)
Default setup
Anyone have a good starting setup for a large dirt track with low to medium traction thanks for your help
tazfam2 is offline
Old 07-28-2014, 03:59 PM
  #3890
tazfam2's Avatar
and a indoor clay track with a 90ft straight
tazfam2 is offline
Old 07-28-2014, 09:03 PM
  #3891
Matt :-)'s Avatar
http://www.tytessman.com/setups/d413-setups.php
Matt :-) is offline
Old 07-28-2014, 10:07 PM
  #3892
racer x 1's Avatar
Trader Rating: 27 (100%+)
can anyone chime in on why TY uses negative* arm sweep? My thoughts are it adds a bit of initial steering without being to edgy? basing this on the fact that arm sweep generally adds mid to exit steering.
racer x 1 is offline
Old 07-29-2014, 05:08 AM
  #3893
lbenton's Avatar
Trader Rating: 48 (100%+)
In two days I now broke three of the rear captured ball cups. None of the three snapped in anything spectacular, not a crash or a cartwheel but just landings off a double. I do not see anything binding or any slop in the rear arms or the rear hub to explain it either. They have broken on both sides of the car as well. It had been running strong for a long time until this.
Bad luck?
Weak point?
Some combo of above?
Or am I missing something?
lbenton is offline
Old 07-29-2014, 06:29 AM
  #3894
Red78's Avatar
Originally Posted by hoofter inc
Had a local sticker guy come up with one from one I cut out. If you're interested he can be contacted at [email protected].
I'm doing something like that but different...I have a vinyl cutter and can make just about anything
Red78 is offline
Old 07-29-2014, 06:36 AM
  #3895
Just finished building the diffs and I just thought it'd be a good idea if they specified how much diff oil to put in by weight as it would make it easier to know how much to put in as the thicker diff oils don't spread easily at all.
moch8 is offline
Old 07-29-2014, 06:56 AM
  #3896
I also found one of my diffs felt a bit crunchy so I backed off the diff case screws slightly and it was much better. Just hope it doesn't leak.
moch8 is offline
Old 07-29-2014, 07:19 AM
  #3897
lbenton's Avatar
Get a manila folder and cut a new gasket... you can make it double thick and crank it down on that if it was binding.
lbenton is offline
Old 07-29-2014, 07:41 AM
  #3898
boudin4evr's Avatar
MAN, that 100K is so thick! I could barely squeeze bottle hard enough to get it out!
boudin4evr is offline
Old 07-29-2014, 07:51 AM
  #3899
Rybeau40's Avatar
Most of the setups being copied are from high bite tracks. Even Ty's low bite setup was on a track with more bite than many of the indoor tracks in the midwest.
I've found using 20-60k in the center depending on layout is most optimal for my particular favorite track. Also, fill the diffs every time. It will add a consistency factor from one diff build to the next as Ty stated in his how-to video.
Rybeau40 is offline
Old 07-29-2014, 07:59 AM
  #3900
boudin4evr's Avatar
did anybody have trouble with their front wheels not fitting the smaller hexes?
they are PL yellow wheels, glued dirt webs front and rears on them, and cant get front to fit!
