Hot Bodies D413 1/10 4WD Buggy
#3049
A fellow racer who got the d413 when I got mine has now broken 2 sets of shock ends. Anyone else having any issues? The bottom is just blowing out of the end on a medium sized jump. Nothing I would consider big or hard landing. I guess maybe hitting something on previous laps may be weakening them then they are letting go. Just a heads up. Keep an eye on yours.
#3050
Ran close to 8 packs today and the car was really durable. I stripped the spur gear and cracked the front shock tower after cart wheeling on a new part of the track. My local track stocked the spare and I was shocked. He also had the ball cup set since I was missing one for the sway bar. I was also running tlr 22 front wheels.
Temps with the 19t pinion and the lrp flow esc were great after putting the esc fan on. Esc was around 100 and the motor hit 155 once or twice.
The shock top popped off the ball twice but I popped it back on
#3052
I am currently using kyosho springs and as mentioned before you sometimes need to thread the shock collars quite a bit down in order to get the correct ride height. Has anyone here used longer springs like those for SC or trucks? I guess not needed but curious in case I ever want more ride height (currently 22mm) and run out of thread.
#3053
we're gonna try to get these to market as soon as we can. but please understand it takes a little while to go through all the processes.
part number will be #114112 but don't try to order it yet as i just barely generated that number. nobody knows of its existence yet. it'll include aluminum caps, bleeder screws, aluminum tower mounts, bushings, bladders (same as stock), mounting screws and washers, enough to do two shocks. price TBD.
#3054
#3056
#3057
#3058
torrence, how about an oring for an emulsion build (so we don't have to cut bladders). would be a nice option.
#3059
Jinx!
#3060
Haha. Missed your post.
