Hot Bodies D413 1/10 4WD Buggy
#2146
Most people are not going to run servo savers. If you don't have an aluminum horn, I would glue the saver and make it as tight as I could.
If you nervous about your servo, I would make it tight enough where I couldn't move it by hand, and set it tighter or looser depending upon how it effected handling when I got to the track.
#2147
I am running a JR Z9100s and tried a HPI/HB like the one Ty is running. I had to use the spare small cups that were with the links, not the really small cups that were in the servo bag. Everything was pretty square, but the throw was really small. Short throws will give you faster movement, but less power and less resolution. I put a Dynamite arm on so I can use 1 hole closer to the spline, but it doesn't stand off as far as the HPI/HB arm, so I put the 1mm shims between the mount and the servo. I am kind of OCD about getting everything square with the steering geometry, so I might change it up again, lol.
#2150
#2151
#2154
Thanks for the help!
#2155
Will the 23T HB aluminum one work? It doesn't have the D413 listed, but maybe because it's too new still. Just looking to see what everyone else is using to make sure I get the right one. http://www.amain.com/product_info.ph...n-23-JR-Spline
#2156
I assume it would work, but I have not tried that servo or that horn in anything myself.
Why not use the servo horn that comes with the kit? You can adjust the tension on it so that it is locked in place. The horn that comes with the kit looks solid enough for any abuse the buggy will see.
#2157
after 10+ packs running outside dusty dirt track I thought I would find dust inside the rear gearbox, but I was surprised it was minimum. looks real clean
#2159
ordered from towers and mine is finally on the truck and out for delivery
