Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread >
Like Tree35Likes
    Hide Wikipost
Old 01-24-2018, 07:02 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: alex4r
Kyosho ZX6.6 New Parts (* = required to update ZX6 to ZX6.6 platform)
LA359B - Center Mount Set (ZX6.6)*
LA375 - Center Diff. Gear Set(ZX6.6)*
LA375-01 - Center Diff. Gear Case Set(ZX6.6)
LA375-78 - Spur Gear(48P-78T/ZX6.6)
LA376 - Center Drive Shaft (71.5/ZX6.6)*
LA377 - Center Drive Shaft (79.5/ZX6.6)* (x2)
LA378 - Center Drive Shaft (88/ZX6.6)*
LA379 - Joint Cup Cover (ZX6/ZX6.6)*
LAW54B-01 - HD Chassis*
LA355B - Side guard set*
UM713B - Rear Arms (from RB6)*
UM561 - Outer rear hinge pins*
LA236-12B - 1.2mm Front sway bar*
LA351B 4-hole front shock tower*
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals
Lazer ZX6.6
Lazer ZX6
After Market Bodies
JConcepts Silencer
Weight Reduction options for 13.5 Class
Chassis:
UMW711B - Carbon composite rear arms
LAW60 - Carbon composite front upper bulkhead
LAW61 - Carbon composite rear upper bulkhead
LAW52 - Carbon composite front chassis brace
LAW53 - Carbon composite rear chassis brace
LA209HB - Carbon composite gear boxes (pinion bearing retainer & upper gearbox half only, lower half not compatible/saves 4.6g total)
Driveline:
LA211B - Plastic drive cups for center drive shafts coming out of front & rear gear boxes (requires drilling two holes for set screws to secure LA379)
TFW001 - Aluminum blade style outdrives (for ball diff/requires TF013)
LA202 - Aluminum pinion shafts (for ball diff)
TFW126 - VVC outdrives (for gear diff - front/rear/center)
TFW008 - VVC cross pins (for gear diff - front/rear/center)
Misc:
LAB06LW - LW Blade body
SK0402 - Ti screw set (Available at Lunsfordracing.com)
PTK-T-2111 - Ti screw set (cheaper, slightly less durable option)
LNS7765 - Ti ball studs
LNS2688 - Ti Turnbuckles
LNS36107 - Ti Turnbuckles (super duty)
W0201H - Hard anodized lower shock balls
1-N3024A-R - Aluminum M3x2.4 nuts (for shock standoffs)
1-N3033NA-R - Aluminum M3x3.3 locknuts
Print Wikipost
Old 07-09-2020, 06:30 PM
  #2416
Brian C.'s Avatar
Originally Posted by soulstice
I just got the zx7 servo holder and it doesn't seem to fit in the ZX6.6. The front upper deck LA357 gets in the way of the mounting holes. Am i missing something?
Did you get this resolved? If not post some pics.
Brian C. is offline
Old 07-10-2020, 09:47 PM
  #2417
Trader Rating: 19 (100%+)
No, basically that chassis brace above the driveshaft is too thick to allow the ZX7 servo mount to fit.
soulstice is offline
Old 07-11-2020, 02:19 AM
  #2418
dmcguire's Avatar
Trader Rating: 38 (100%+)
What about removing the brace and replacing it with a turnbuckle to the center diff?
dmcguire is offline
Old 07-14-2020, 01:46 PM
  #2419
Definitely could do that, could also run a carbon top plate too. I guess I was just trying to figure out if I missed something obvious or if using the ZX7 mount requires other parts to be changed. I thought it would be a part for part direct replacement but doesn't seem to be the case.
Old 08-26-2020, 04:08 PM
  #2420
Originally Posted by azeroth
I like the changes most I have done. I have been running gull wing arms on one of mine with AE hub carrier and knuckles and with gear difs and slipper is the only way to go would of like to seen updated ballcups and balls so you don't have to drill or replace them with lundsford but that's trivial would of liked to see provisions for motor fan mounting for the stock classes but it should be a step in the right direction
Are the AE hub carriers a direct bolt on to the kyosho zx7 ?
carpetburner is offline
Old 10-01-2020, 08:25 PM
  #2421
superdave138's Avatar
just run the floating servo mount
superdave138 is offline
Old 10-02-2020, 09:01 PM
  #2422
alana07's Avatar
Trader Rating: 53 (100%+)
A little late to the party here but just gotten a 6.6 kit. Is running the stock centre diff with fr/rr geared diffs OK for a bumpy dirt track? If yes, what oil combo would be a good starting point?
If no, would the centre diff work well with the kit ball diffs or do I need to get the centre slipper clutch setup?
Thanks.
alana07 is offline
Old 10-04-2020, 12:39 PM
  #2423
Thanks.
I think you can run all 3 gear diffs, I wouldn't go for the slipper. I used to run a ZX6 with centre slipper and gear diffs front and rear. The centre gear diff would have been better though. This is a bumpy dirt outdoor track. While ball diffs seem to be preferred for low grip, I find gears easier as they don't require adjusting, just change the oil. I have switched to an HB D418 and that has centre gear diff and gear diffs front and rear.
I would try 100k centre and around 3k rear and 5k - 7k front to start.
jgil089 is offline
Old 10-04-2020, 05:36 PM
  #2424
alana07's Avatar
Thanks for the heads up.
alana07 is offline
Old 02-18-2021, 09:52 AM
  #2425
Picked up a used ZX6 to ZX6.6 conversion from the forums (thanks speed90!). Planning to use it at the backyard track and some occasional club racing on clay. Has the ZX6.6 chassis, center gear diff, floating servo mount, and ball diffs front/rear. Went with a Hobbywing Ezrun Max10 60a 5400kV waterproof system so I can use it on days like this! Seems like the Hobbywing system should have enough speed for 4wd mod, though its hard to tell right now with the low traction.
Arcain41 likes this.
Khan48 is offline
Old 04-25-2021, 02:33 AM
  #2426
Default Servo on opposite side
Hi Team,
know the post has been dormant for a while but how did you mount your servo on the rh side of the vechile? Also I'm building the 6.6 for stock racing planning on running the ball diffs for less rotational mass, how light did you get yours.
Pollockmarine is offline
Old 04-26-2021, 06:41 AM
  #2427
The original ZX6 chassis drops a ton of weight.
scoobyrs25 is offline
Old 04-28-2021, 08:14 PM
  #2428
Trader Rating: 96 (100%+)
Originally Posted by Pollockmarine
Hi Team,
I have a ZX6 and I flipped my servo to the RH side, IIRC I had to modify the mount, which is not the floating one, it's the diamond shaped one.
Eric Tomczyk is offline
Old 05-04-2021, 11:12 PM
  #2429
foampervert's Avatar
kyosho steel is the most interesting. Just be sure to properly dry it out and oil all the steel bits... kyosho steel can and will rust... still pretty tough... but things are less peachy when rusted.^^ btw... since the beginning... you know its proper kyosho when the steel rusts... hahaha
foampervert is offline
Old 05-05-2021, 09:07 AM
  #2430
OffRoadJunkie's Avatar
I have a TLR, Traxxas, and AE cars that has rusted metal. Metal rusts. The only thing that will keep it from rusting is the coating. I haven't seen a difference in one brand being better than the other.
OffRoadJunkie is offline
