Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
#2282
I used to use the plastic LA211B parts on mine, but you really have to keep an eye on them. Very important to use the proper o-rings on them to keep them in place, or the fronts will fall out.
They also start to spread and get gouges in them over time. I went back to the steel ones and added the LA379 pieces. No need to put the o-rings and just much more durable.
#2284
Had a good time at the track! The ZX did fine for our first time running 4wd. The biggest thing we learned was how difficult it is to get used to 4wd then switch to 2wd. He practiced a lot with the 4wd and it was clear that it threw him off in 2wd. He did much better with it by the end of the night.
#2286
#2287
Interesting, I don't remember every having a problem with them separating on the ZX5, even using a mod motor back then. Maybe because it had a slipper. Regardless, LA379 should solve the problem. They weren't hard to drill out using the sleeves as a template. They're super cheap to replace too when they wear.
I wish Kyosho would have updated the front diff case to not have such a drastic pinion angle as well. Would have fixed all these problems.
#2288
#2289
Is it possbile to mount a gopro on the body? Will the body hold? I can't see any mounting points from body to chassis. I'm worried if the body can't hold a GoPro.
#2292
Rev version. 78/26. It was a screamer until we started getting a sensor fault from the speed control. We tried everything. Changed the wire, tried the other sensor plug on the speed control, went through the program box. We finally changed the motor and it was fine. I could bench test it and it seemed fine. It would run on the track for a while before throwing the fault so I think it might have broken a fiber washer and had too much endplay. Endplay felt really excessive. I took it apart yesterday to check it out and found all the screws were loose also so who knows. I bought it used so definitely not knocking Fantom. Motor is strong. We'll try it again next time.
#2293
