Tekno ET48 Thread >
Tekno ET48 Thread
Like Tree38Likes
Tekno ET48 Thread
Old 12-27-2013 | 09:50 AM
  #901
Originally Posted by symmetricon
I highly doubt you will make 10min with 4600mah.
He could make 10 min. easy I can make 10+ minutes with a 3500mah in my ebuggy.
masin14 is offline
Old 12-27-2013 | 10:12 AM
  #902
Cain's Avatar
Tech Legend
It will be close, but I think he can make it.
When I ran my 1/8 E Truggy back in the day, a converted RC8TE, when I tried the 4900mah PolyRC packs at the time I was getting about 13 minutes max runtime in the winter on slick conditions, but track (200 ft straightway) using the castle 1515 2200Kv motor. Tires were old school MT style stuff too.
Depending on his driving style and if he goes lightweight, it may work. It will be interesting to see thats for sure.
Cain is offline
Old 12-27-2013 | 12:06 PM
  #903
symmetricon's Avatar
I have no idea how on earth you guys are getting so much run time. I am quite smooth on throttle, no drifting, a lot of feather the throttle. In 7 min on high or low bite, I use around 4000mah..... Maybe you guys are on your lid a bit? E buggy, yeah, I only use 3000mah in 7min....
symmetricon is offline
Old 12-27-2013 | 12:12 PM
  #904
I see people post that kind of stuff from time to time on here too. still find it hard to believe.
Mullet1 is offline
Old 12-27-2013 | 12:17 PM
  #905
Cain's Avatar
Tech Legend
no worries. I remember my disbelief when guys where posting getting 25 minutes on a 5000mah pack when 1/8 electric was first starting. And these guys aren't on there lids
They did do it though, but, how they drove was a strong factor in it and track layout and conditions matter too.
In general, i don't feather the throttle, I try to keep a constant input to the throttle as that is what I am used to and shoot to maintain speed through the turns. others I see will kill the brake then gun it to through. Never could get used to that at all.
Lots of factors come in to how much runtime you see. but I have been there, done it, and saw it. I couldn't get to the mythical lands of 25 minute runtimes on a 5000mah pack, but in low traction, slick conditions where the weather outside was in the negatives and indoors you were about 32 ish from what I remember which was "warm" and hence, in the cold would affect the batteries, it was able to get that kind of runtime.
Crashes, marshalling needed, sure. but I wasn't sitting on my lid for minutes on end.
looking at what you are guys are seeing for burn through time of say 4000mah in 7 minutes, you are doing about 570mah a minute?
When I did E-truggy back in the day, my goal of a battery pack was to get one that would last a guarenteed 15 minutes. the PolyRC 6000mah 25C lipos of the day did this. I could average about 17 minutes in a truggy from fully charged.
Track conditions were Pingree RC Park which you can find on youtube.
Cain is offline
Old 12-27-2013 | 12:38 PM
  #906
UK.hardcore's Avatar
Traction is the big factor in power output.
I used to get 14 or 15 minutes with my rc8t from 5500 4s with mamba 2200.
The ET48 is likely more then a pound lighter so it should be possible.
UK.hardcore is offline
Old 12-27-2013 | 01:12 PM
  #907
Cain's Avatar
Tech Legend
+1 . For my needs, that is why at the time I looked for batteries that woudl give me a guarenteed 15 minutes for the places I ran and conditions.
May be worth doing that if you have any concerns about runtime you need.
Cain is offline
Old 12-27-2013 | 01:22 PM
  #908
skengines's Avatar
What 4S LiPo are you guys running in ebuggy?
skengines is offline
Old 12-27-2013 | 01:35 PM
  #909
Cain's Avatar
Tech Legend
was running 5400mah packs I picked up from promatch. may go with 6500s next all around or, could do dual 7200mah 2S with that male to male plug they make. On the heavy side but getting some reuse is a plus
Cain is offline
Old 12-27-2013 | 05:08 PM
  #910
I get 17 mins on a tekin 1500 KV motor and Gen 2 rx8 esc , with a gen ace 5000 mah 40c pack running in series 2s and 3s for 5s configuration on RC8t no problem leaving about 20 % left on the lipos , and i run on a big 1/5 scale track some what technical on the inside but open on the outside with a couple of big table tops and yes we need the mud guards out here
mavdriver is offline
Old 12-27-2013 | 05:20 PM
  #911
I had TQ and was cruising for first at our last HARC race/ Toys for Tots when I dumped on the last laps ( still took 3rd ) I was using a tekin 2000kv motor with 2x2s 7200mah IP packs from pro match. It was cold out (30-40deg). I charges the batteries up to see how much I used, and had put approx 7000mah back in... I was trying to coast and take it easy too, the track was medium bite due to the cold. Most of the e truggies dumped as well while using 6500+ mah......
Old 12-27-2013 | 05:51 PM
  #912
FastPete's Avatar
I use twin 5600 Nano techs 10 minutes uses 3200 mah in my 1/8 scale buggy.
FastPete is offline
  #913
I know you guys doubt he could make it but if I can make 10+ minutes with a 3500mah pack with a 1900 kv motor I am very confident you could make 10 minutes with a 4600 pack . And I am not flipped much at all.
masin14 is offline
Old 12-27-2013 | 06:41 PM
  #914
mydudrevo's Avatar
I would really love to see someone come down to Houston for roar E-nats and expect to make 10 mins in truggy on a 4600. You would be severely disappointed when you dump and loose. Not one single person down here can make these mythical 30min run times on 7200s myself, symmetricon, and mullet included its just crazy to even think that.
mydudrevo is offline
Old 12-27-2013 | 07:33 PM
  #915
8ight-e's Avatar
Will the Hobbywing Xerun 150a esc fit in this truggy? Seems like an odd design to be so tight on the ESC with so much room!
I've raced etruggy for years.. good 6500-7000 packs in a 4s config will get you 14-15min in a reasonable setup (1900kv range) this will be a struggle as the packs age. I push my etruggy 17~20min fairly often racing; but to do so I use a 1550kv motor and 6s 5000mah lipo, this is safe and I've found reliable. To make a 30min race I need to swap packs no if and's or buts... it would take a BRICK of a lipo to make 30min on one pack. I did a lot of tq, wins on a huge 1/8 track.. w/ a long straight and motocross style jumps.. obviously you can reduce needed mah/min taking the track and driver into consideration. The 4s configs lose run time pretty quick, weaker packs tend to poof pretty quick as you push past 12 minutes of racing on a regular basis. At 4s the amp draw is pretty significant in the etruggy, so it's a real torture test on your packs. BTW I use to really like the IP packs, IMo they suck these days buying from promatch or anywhere they poof in no time, still usable but poofed.
8ight-e is offline
