Help with 1/8 MBX6ECO set-up/problems >
Old 05-14-2013, 08:24 PM
  #16
symmetricon's Avatar
Trader Rating: 27 (100%+)
do you lose steering and throttle?
symmetricon is offline
  #17
U shouldnt have problems with that radio.. Man u got me stumped.. Try running it with just the rx8 and servo plugged in and go from there
Losi8ightfanty is offline
Old 05-14-2013, 08:35 PM
  #18
At this point i have switched the transponder and the BEC around so now i have the bec in the bind/batt slot and the transponder in the aux slot. It all appears to work fine now but i wont know if i have fixed my issue with jumps till i get it outside again(waiting to get the servo/trandponder/BEC mounted in place as i am still unsure of what exactly to use/where to put them.
(hoping that switching the transponder/BEC around fixes the glitches i was experiencing but unsure as of now)
I believe the first time i tried it that way i may have had the servo plug in backwards which is why i had it switched around i think(steering wasnt working and i think i relocated the whole rx to make wires fit better due to length cuasing me to unplug the others in the process which would be where i confused myself). Rookie mistake
Still curious on which wires i need to keep separate going into the rx box to avoid interference as well
Thanks again for all feedback everyone
cmeans_23 is offline
Old 05-14-2013, 08:39 PM
  #19
Originally Posted by cmeans_23
i edited the above post with my finding on the HV compatibility
Sorry if I didn't help much. I tried but I hope you the best of luck! I hope you get back on the track soon!
Old 05-14-2013, 08:41 PM
  #20
Yea its as if the receiver gets disconnected. I can rebind and go again till it bottoms out on a jump
Old 05-14-2013, 08:43 PM
  #21
Well i know it ran fine for at least a battery pack without the BEC/transponder hooked up on this set-up and appeared to be fine. I only hooked up the BEC cause i was concerned i would run into problems with the transponder running as well. And i also felt better about taking a load off of the esc. Also dont be sry by any means i greatly appreciate any help i can get on here. Thanks again
Old 05-14-2013, 08:44 PM
  #22
and you didnt have the prob before the bec? that is real weird. it is possible that your rx is bad, or may have dirt or debris in it. i have had issues with my futaba rx's when they get dirt in them....
Old 05-14-2013, 08:45 PM
  #23
I have my transponder mounted on my receiver box cover. Works good for me
Old 05-14-2013, 08:46 PM
  #24
I did buy it used and when i ran it before the BEC install i was also on my other RX(sr300) didn't think to mention that. So maybe that is something i need to consider as it was a used rx i bought off of a local.
Old 05-14-2013, 08:47 PM
  #25
On the outside i presume? That is probably a good idea. I have enough room that i can fit it inside the rx box too depending on how i mount the rx. I orignally had it there but unsure of how i am going to mount the rx i figured i'd ask for more opinions
Old 05-14-2013, 08:48 PM
  #26
Ohhhhh I don't think your dx2e is dsm2 capable. Correct me if I'm wrong and sorry if I am but I think only dx3s and dx3r and maybe dx3c is dsm2 capable. The rx your using is a dsm2 rx and your tx is only a dsm1 capable
Old 05-14-2013, 08:50 PM
  #27
it is compatible just double checked.
Old 05-15-2013, 07:56 AM
  #28
Trader Rating: 55 (97%+)
I don't know much, but, I'm thinking it has to do with the tx/rx.
Spectrum just doesn't cut it for me....... but, please read first statement before anyone decides to flame me about it
shagnat is offline
Old 05-15-2013, 08:21 AM
  #29
Zerodefect's Avatar
Direct power your servo and Rx. See if that solves your "brown out" problems.
Find a local racer that can help you with Mugen shocks. There is no shock help in the Mugen threads on Rctech. Mugens have weird shocks, which is why I quit using Mugens.
Yeah, allway curve your motor wires forward, not back. The Protech 4100 lipo is a good fit for the Mugen. The JConcepts Finnisher body is great fo the Mugen. Leave an extra 1/4" under the body and secure it with velcro. I removed my body posts.
Zerodefect is offline
Old 05-15-2013, 11:21 AM
  #30
MajorKong's Avatar
I have the same receiver as you in my MBX6E. I use a HV servo also, Savox 2274SG. I have a Novak glitch buster plugged into the bind port on my receiver. The glitch buster is stuffed in the receiver box too. I notice that you do not have an antenna tube in the pic. I know it sounds unlikely but I find that Spektrum receivers can be particular about antenna placement. I would get an antenna tube if you don't have one. I thought it odd when you mentioned that the RX seems to cut out when you land.
Are you using a shock cushion on the bottom of your RX? 2 sided tape, velcro or something similar.
Good luck.
MajorKong is offline
