TLR 8IGHT E 3.0 THREAD >
Like Tree2Likes
Old 11-07-2013 | 11:11 AM
  #931
drepus's Avatar
Originally Posted by JoeC
Ok, for you guys that have ran shortys and brick packs indoors can you please share you experience with them. Did you like the way the buggy handled with one over the other and if so why? Also for those of you running shortys where do you like to place the battery. I noticed with the shortys that if you run the pack up front it leaves a lot of empty space at the back of the tray. Thanks.
With shorties the car weighs quite a bit less. It will accelerate faster,brake in less distance,jump higher,turn faster etc which is great for tighter more technical tracks that dont need a ton of power.Basicly it will be more responsive and nimble feeling. Indoor tracks usually use quite a bit less power so runtime is not normally an issue with the shorties.
With brick or full size batteries the motor will have a little more grunt and have more overall power. The car will be a little lazier in the turns and will feel a little more stable at the expense of some corner speed.
drepus is offline
Old 11-07-2013 | 11:45 AM
  #932
Thanks for the reply. For those of you guys running shortys does there seem to be a sweet spot on where they should be placed in the battery tray. I think I remember Casper saying that him and Ryan ran theirs almost all the way forward?
JoeC is offline
Old 11-07-2013 | 01:27 PM
  #933
sunco1's Avatar
Found a sneak peek for those looking for aftermarket bodies
sunco1 is offline
Old 11-07-2013 | 01:46 PM
  #934
Casper and I have tried them all over and with our setup, we like them 1 pad back from full forward.
hacker07 is offline
Old 11-07-2013 | 03:31 PM
  #935
TimMo846's Avatar
I just found one on Ebay actually...... but it's for the nitro. Was about to post and ask if there was any chassis width difference or not?
TimMo846 is offline
Old 11-07-2013 | 04:11 PM
  #936
rcgod's Avatar
Does the 2.0 motor mount fit the 3.0?
rcgod is offline
Old 11-07-2013 | 06:38 PM
  #937
Outtacontrol58's Avatar
Hey ej that's gotta be it! I see the air hole and that is Chris V's 3.0e from Florida. Thanks for sharing. Can't wait to see more angles and the official release.
Outtacontrol58 is offline
Old 11-08-2013 | 07:32 AM
  #938
No, it does not work correctly in the 3.0e.
hacker07 is offline
Old 11-08-2013 | 07:57 AM
  #939
rcgod's Avatar
OK thanks.
rcgod is offline
Old 11-08-2013 | 08:01 AM
  #940
ROSCOE's Avatar
For the guys running the TI upper shock standoffs, when you shim them out enough so the shock clears the tower is there still a sufficient amount of threads left for the nylon lock nut to catch and do its job? I would think the standoff would get revised do to the move toward 16mm shocks on the 3.0s.
ROSCOE is offline
Old 11-08-2013 | 02:42 PM
  #941
ROSCOE's Avatar
Well I ordered them anyway! At $5 a set I couldn't pass them up. Now that I've got all I wanted ordered I might as well pass on some deals. For any ebay shoppers hopmeup is having a sale on Losi goods. I got the tlr TI shock standoffs for $5 a set, tlr option rear axles for dog bone option for $5, rear option dog bones for $5 and more. It's not my store by any means but figured id share.
ROSCOE is offline
Old 11-09-2013 | 07:07 PM
  #942
JasonR/C's Avatar
Default Eye Candy
A local just dropped off my new 3.0 body, car stand, and pit board with my new scheme!! Absolutely sick! Thanks Eye Candy!!
Attached Thumbnails TLR 8IGHT E 3.0 THREAD-1382312_244839082339349_523935570_n.jpg
JasonR/C is offline
Old 11-09-2013 | 07:15 PM
  #943
Wow...Looks Awesome!
C.Capelo is offline
Old 11-09-2013 | 07:27 PM
  #944
JasonR/C's Avatar
Thanks alot!!
JasonR/C is offline
Old 11-09-2013 | 07:39 PM
  #945
ROSCOE's Avatar
Definitely some eye candy there! Looks good!
ROSCOE is offline
