TLR 8IGHT E 3.0 THREAD
#781
Joined the 8ight Buggy Club!
Woohoo! Just expanded my TLR arsenal with a new 8ight-E 3.0! Going over the setup sheets and forums and looking for verification on product compatibility:
Which aluminum servo saver arm fits the E3?
Has the differential parts for the E3 changed? - More research indicates it has not.
Will the Aluminum Rear hubs and CV axles fit as well?
Looking forward to the build but going to take my time (it's so hard not to jump right in haha) as I'm already waiting on some hopups to arrive. Maybe I'll just start with the shocks. And who has the rear green springs in stock lol. My goto shops are out, not even eBay!
#782
I've got one on the way, gonna put my Eb48.2 up for sale!
#783
Does the Tekin rx8 gen2 come with long enough wire for the E 3.0? If I need to buy some, what gauge should I get?
#784
Yes, the enclosed three wires (red, black and white -- all 12 gauge) are long enough, but the sensor wire that comes with the Tekin products is too short. And 12 gauge Wet Noodle wire by Deans is the best we've found if you feel the need to buy any for battery connectors or such.
#785
congrats to those of you recently getting this kit!! its an amazing car, ive been wheeling it since release! your going to love it! if you have setup questions id be glad to assist you any way i can. just PM me with a question. Also ryan and casper are always helping out on the forums. If you want professional help ask them! They are very helpful
#787
#788
i got an viper 280mm sencer wire at amain very nice
#789
Hello Guys,
is there any information on when there will be additional bodies available ? Don`t get me wrong i love the stock body i just wondering if there will be a jconcepts silencer for the 3.0 E ?
#791
#793
trouble!
Well I am having some trouble with setups for my 8Ight 3.0 e,
Running r8 pro and a 1750 on a smaller to medium indoor track
After 8 minutes of run time esc was 178 and motor was 168. Which seems a little bit of a lot to hot.
Changed from a 17t. to a 16t. pinion with no change in temperature.
Fan also broke while I was there, but the local track pro told me that the fan isn't needed in an r8 pro and he showed me his car, in which it was removed.
Are these temps safe or should I be worried??
#794
your esc temps seem alittle high. mine usually peaks out around 125-130. im using the same esc also. i removed the fan. make sure the vents in the body are cut out. people seem to be afraid of motors hitting 160. my motor LOVES 170-180 temps. in fact it runs better warmer. unless your motor is over 200 i would never worry.
im also looking for a new body. yet nobody is making anything yet.
#795
JASONr/C
What are you running for a pinion in your buggy? I am quite worried about the esc temp. I am also wondering if the esc got this hot because the fan was broken and trying to turn? maybe causing extra heat? I am not sure.
Geared at a 16t seems about perfect for my track. maybe just not my esc?
