Tekin Pro 4 HD Factory Thread
#497
I'm running oval with a scte. I have a pro 4 4000kv motor currently with a 15t pinion. I am running 40% timing and 90% current limit. I am getting blowed away down the straight. I am not sure what motor the other guys are running. I need more top speed but also need more out of the corners. So I need the speed of a 17 or 18 tooth pinion with the torque of a 13t pinion. What motor would you recommend? Would the hd 4300 be faster than a 4600 or a 4.5 redline sc motor?
The 4000kv is fast but the 4600 is faster. The Pro4HD would have more torque and can pull a bit more gear.
#498
#500
Ok. Thanks. Now to make a decision on which way to go. Am I correct in guessing the 4300 geared correctly would go as fast as the 4600 and have more torque doing it?
#503
I guess I'll be ordering a HD then. LOL
#504
Make your life easy and go with the HD 4300 and don't look back. There is a reason why it is the latest and greatest motor. I can't wait to use mine in the new build.
#505
"Latest and greatest motor". That's a rather bold statement for a motor that really has no practical use. This Pro4 HD is balls off the walls crazy. The regular Pro4 motors are still overpowered for the current lineup of 4wd SC trucks we currently have. The 4300 is best suited for 1/8 size tracks, if your indoors or on a 1/10 style track, the 3500 is plenty. Stuffing in more power isn't going to make you faster.
#506
#507
I am preferential to large outdoor tracks so works great for me. However, the 4300kV HD can still do very well inside for those who can control it. I see the fast pro drivers running either 4600kv and or 4300kv motors inside on the 10th scale track as well. I agree that more power isn't necessarily faster especially for those less experienced.
#509
need some assistance with esc setup for the pro 4 hd 4300 in a lost scte 2.0 16/40 i believe . temps are in the 200's . Please note that i am in texas racing a 10 min qualifier
http://www.teamtekin.com/hotwire/ESC...heet-blank.pdf
#510
