Hot Bodies D812E-Conversions
#361
#363
-HB D812
-Tekin RX8 Gen 2
-Tekin Gen 2 1900 motor (Geared 48/21)
-Hitec HSB-9370TH Brushless Servo
-RC Monster D8 Lipo/ESC Tray (Slightly modified to clear inner rear hinge pin nut)
-Elite RC D8 Motor Mount
-HPI Vorza Receiver/Servo Tray
-HB DCJ Front Center Shaft
-Tekno Rear Center Diff Coupler
-HPI 110mm Rear Center shaft
-HPI Vorza Center Diff Cover
-HB Version 2 wing mount
-HB Sway Bar Kit (2.2 fr/2.4 rear)
-HB Front Yellow Springs
-HB Rear Blue Springs
-Lunsford Titanium Turnbuckle Kit
-Fastener Express Aluminum Purple Screws
-Anodizing done by Carolina Custom Anodizing
-Tekin RX8 Gen 2
#365
Will the d812 shock towers work on the d8?
Was wanting to put longer shocks on my Tekno converted d8 and use the d812 shocks and towers if possible
#367
#368
-HB D812
-Tekin RX8 Gen 2
-Tekin RX8 Gen 2
RC-Monster D8/D8T 51.5x160 battery tray-RC Monster D8 Lipo/ESC Tray (Slightly modified to clear inner rear hinge pin nut)
RCRD8-Elite RC D8 Motor Mount
103674-HPI Vorza Receiver/Servo Tray
67217-HB DCJ Front Center Shaft
TKR5075-Tekno Rear Center Diff Coupler
103665-HPI 110mm Rear Center shaft
103668-HPI Vorza Center Diff Cover
114414/114415-HB Version 2 wing mount
68188/68191-HB Sway Bar Kit (2.2 fr/2.4 rear)
109809-HB Front Yellow Springs
109814-HB Rear Blue Springs
2861-Lunsford Titanium Turnbucklle Kit
Seriously looking at doing something very similar to this :-)
#369
109428-HB D812
???-Tekno Rear Center Diff Coupler
???-HB Version 2 wing mount
Seriously looking at doing something very similar to this, but either can't find the part number or there are more than one possibility and the Elite motor mount appears to be out of stock
Tekno coupler is #TKR5075
I emailed Elite to find out when more D8 mounts will be back in stock. I ran the RC Monster one this past season and it worked good.
The Version 2 HB Wing mount is not available to the public yet, but here is the part number for it #114414 and the +10mm wing is #114415
#370
Thanks Jeremy, I updated my post with the remaining part numbers. Your conversion looks super sharp. Time to go spend some money... LOL
#372
Just a reminder for people who want to do the conversion.
The front grub screw for the diff coupler is too long. Replace with a shorter one or dremel. The steering rack will hit it in max lock. Also check that the front pin has a indentation or it will fall out. Mine didn't and the first run it disappeared. Weird that they haven't fixed that in the kits yet.
I also dremeled the steering rack ends at the lower part, where the bushings go in by about 2mm and took that amount of the top of the metal bushings. Also put a Tekno front coupler with retainer sleeve in.
#373
#375
