Hobbyking 60A ESC
#16
Im running the turnigy 35a paired with the turnigy 10t brushless setup in the traxxas stampede....it has its ups and downs i guess and heres what i mean: without the program card,its hard to tune and adjust that esc.When running a 3cell,you have to disable the esc fan so you dont damage the fan.It has a problem with reception,it seems to lose signal randomly..BUT.........the fan on 2cells,or nimh is awesome! keeps the esc really cool,it works extemely well with the turnigy motor,doesnt get the motor extremely hot even on 3cell lipo,its got quite a bit of power in it as well.....plus....its really cheap to get and you dont have to spend alot if your just looking to goof off with it
#17
I'm interested if anyone has opened up a Hobbyking or Turnigy ESC and compared it to an equivalent Hobbywing.
People seem to assume they are all the same, but different manufacturers can spec what sort of components go inside it. If its the same, thats super awesome and I'll pick one up, but I would not be surprised if the Hobbyking/Turnigy are using lower rated/quality FETs, caps/resistors, etc.
#18
#19
i have had the other no name yellow case xerun copies and plugged the bottom board into the top xerun board and it worked perfect , i no ececs expert but everything inside them looke pretty similar to me . that esc still runs perfect about a year later . ive also used the purple bullistorm copies wwith great results and no issues , these one's started out cheap but are now the same price if not more than xerun , the hobyking ones will probably be great and the cheapest yet !!!!
#21
I've got one coming so once it arrives, I will try to get both apart and take photos of each to compare. From what I've heard they are very similar in performance and appearance. Also run on the same hobbywing software so fingers crossed they are great. Ill keep you posted though!
+1, if they are as good as what I've heard and run on the same software I can't see a better speedy for $ on the market. I'm also curious if they run with the hobbyking software I'm assuming it will also run with the Professional program card also?
#22
It worked great! I changed a whole bunch of settings and they all seemed to take. (Though setting Break and reverse is more obvious than changing timing). The only think I didn't try was updating firmware. I assume that works, but didn't want to brick my ESC...
I'm in the middle of assembling some photos so that someone else can compare them to the Hobbywing ESC..
I'll post them when I get a chance...
#23
Some pictures
Here's what it looks like out of the box. Shouldn't be too hard to take apart...
#24
There you have it guys, clearly it's pretty much a copy if it takes the same software. Glad to hear it works as I have ordered mine and awaiting its arrival. Definitely something I will be doing further testing on once it arrives. And to see if it works with the HW professional programming box and works with the HW blinky mode.
#25
Hmm...
Turns out the crimps on the fan wires aren't up to snuff, so if you take it apart, just be careful...
Here are the shots below. Looks like the 60A and the 120A are identical, except for the missing components on the upper board.
Inside the ESC, there is a two board "sandwich". The lower board looks like all the logic. The upper board are just FETs. There are also some spots where there is a FET missing. I'm curious if I could just buy the right FETs, solder them in and have a 120A ESC...
Anyway, since I have no Hobbywing to compare it to, it's impossible for me to know whether it's a clone or the real thing. Anyone open the Hobbywing version?
#26
Hmm...
IMO I don't think they will be very different, if any different at all but we will see I guess.
Have you had a chance to put it in a car and drive it to see how it goes?
#27
Hmm...
Again, Awesome work mate! Good that we now have pics of the Hobbyking ESC. I personally haven't opened my HW ESC but will if I get the chance to compare.
dont be surprised if majority of the components are similar.
#28
Yep,
It's brother (or sister) is in the B4. I ran it in a beginner's race and won (I don't think that beating a bunch of kids is really a true test of anything, tho!) I've got the Turnigy Trackstar 17.5 running on a 69 spur, and 29 pinion. Both the ESC and motor are barely warm at with this combination.
I would say that it's very smooth. I was running a 19T brushed motor before this and I would say that's it is just as smooth as brushed (maybe moreso!) Reverse is a little funny, though. Sometimes I have a difficult time getting it to work. It almost seems that you can't have reverse unless you brake first. If you let the car roll to a stop using drag brake, hitting reverse does nothing. I find it takes 3 or 4 tries before I can get it to reverse.
I also haven't figured out what the button next to the power switch is.
#29
Yep,
I run a very similar setup in my b4.1 and same story, motor and ESC are barely warm by the end of each run
#30
From what I can see and read they are all practically the same ESC. One difference between them all.... The Price.. don't get me wrong hobbywing and Brushless hobbies are still very cheap compared to other brand ESC with the same specs but the Hobbyking X-car is a clear winning in the price department
