Help with 22SCT
Help with 22SCT
When I first raced this truck it ran great and I was always finishing 1st or 2nd at my local track. I ran for roughly 6 to 7 races before this problem started to develop. I never changed anything on the setup because there was no need to. Now that this problem has developed I started tinkering with setup changes to try to fix it to no avail.
The problem is in high speed turns at exit the rear end will kick out and spin me around. This happens at one local track where a long straight goes into a long sweeping turn. On the exit of that turn the rear of truck will just spin around. On another track yesterday there is a long straight then 90 degree turn into a short straight. On exit of the 90 it does the same thing. This truck is hooked up on all the other turns which are low to med speed turns. I mean I can hug the corner and dive right down underneath people as they can't turn as sharp and take things a little wide.
I'd really like to fix this and start being competitive again but have no idea where to start. I have dropped from 1st and 2nd to 6th or 7th now.
Attached are some pictures of the exits where the rear will whip around.
I'll try to list my setup as much as I can. Think stock as the manual but with these changes.
Stock blue spring front
Stock white spring rear
Front and rear bottom shock location outside
Front Top Middle Shock Location
Rear Shock location 1 in from outside
27.5 losi oil front
30 losi oil rear
Team Losi Racing 4mm Aluminum Trailing Spindle Set
Team Losi Racing 10° Aluminum Hub Carrier Set
Team Losi Racing Aluminum Servo Mount Set
Team Losi Racing Aluminum Battery Tray
Battery location 1 foam in rear
Team Losi Racing Aluminum Rear Hub Set (location middle of the set of 3)
Team Losi Racing Aluminum Rear Motor Rear Camber Block
Team Losi Racing Aluminum 3° Low Roll Center Toe Plate
Team Losi Racing Aluminum 30° Front Pivot Block
27.5 losi oil front
30 losi oil rear
