TLR TEN-SCTE 2.0 Kit Thread
#5657
Anyone running the JC Titan body and having issues mounting it? I used their included template, but the holes aren't lining up properly with my body mounts. My buddies and I noticed my chassis was bent and thought that might be moving the body mount locations forward. I swapped out chassis' and it's still having the same issue. I'm curious if the template locations for the SCTE 2.0 are off? I drove the truck all summer, but is there any chance I put something together wrong that would cause the body mounts to end up too far foward?
I've asked everyone I know locally and we can't figure it out.
#5658
The 2.0 does use spacers for the body mounts do you have those in ? And yes a bent chassis will do the same.
#5659
I was just surprised that w the new chassis, the mounts still line up identically to where they were w the old one.
#5661
#5663
Fresh install - 4700kv with Castle MMP.
Looking for help setting up Timing to run in my SCTE; C.H.E.A.T mode they call it in Castle land.
Planning on running SmartSense initially to try it out. But if anyone figured out the perfect combo of timing boost and activation range, I would greatly appreciate it.
Thanks.
Thanks.
#5664
two questions:
1. Will a SAVSC1256TG work. Its a spare right now
2. Foam inserts for indoor clay. Any recommendations.
#5665
#5668
#5669
Thanks for the info to;
urluzn
bds81175
kingofcool999
rob4448585
Another question
After going down the straight, my front turns the corner great but my rear swings out.
I use standard sway bars, black front, silver rear springs and diff is 5-5-3
Thanks Again
urluzn
bds81175
kingofcool999
rob4448585
Another question
Thanks Again
#5670
Ok guys been running a tekno and just sold it ,and new 2.0 be in we'd. Any common spares or weak links, or upgrades to do right off
