TLR TEN-SCTE 2.0 Kit Thread >
Like Tree10Likes
Old 08-31-2013, 09:35 AM
  #5116
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
I've got a tuning question that gets down to a pretty detailed level. I'm a bit sluggish turning in but a little tail happy exiting the turn. It seems like a roll center imbalance but I'm not positive. What would you all do to fix this?
bds81175 is offline
Old 08-31-2013, 11:40 AM
  #5117
might want to try moving the upper arm clips to rear of arm.
hope this helps.
m2cracing is offline
Old 08-31-2013, 08:42 PM
  #5118
Hi I really could use some help. could some one post a pic of the proper new steering setup. ball down inside, ball up outside , 2mm washer under ball flange outside to spindle. -1 degree toe in. If I am missing something or this does not seem correct please help. thanks for the help.
Dirty Harry is offline
Old 09-01-2013, 04:13 AM
  #5119
Purdue Engineer's Avatar
You have it right. What exactly do you need help with?
Purdue Engineer is offline
Old 09-01-2013, 07:01 AM
  #5120
darkstar1974's Avatar
Trader Rating: 34 (100%+)
i'd love to see a picture of this as well. I don't think I'm set up that way and don't fully understand exactly what you're talking about.
darkstar1974 is offline
Old 09-01-2013, 07:19 AM
  #5121
On the steering links; the ball ends have a washer/spacer on one side. Put the washer up on the bellcrank (ball will be at the bottom (Bump down)). At the spindle; put washer down (ball will be up) and also put a 2mm spacer under the washer.
Old 09-01-2013, 07:22 AM
  #5122
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
What setup?
Frank Root is offline
Old 09-01-2013, 08:55 AM
  #5123
Originally Posted by Frank Root
What setup?
What hinge pin inserts do you use?
1488rider is offline
Old 09-01-2013, 01:29 PM
  #5124
BmainStar's Avatar
Originally Posted by carbons2k
I could use a touch more steering from my 2.0. I have the steering collar locked down at the moment and feels great. Like I said I'd like a touch more steering without sacrificing rear traction and making it ass happy. Any ideas?
An easy trick is to unhook the front sway bar and give it a run. I find on small to medium sized tracks running with no front sway to be the ticket.On bigger faster tracks you will notice some lift and roll thru fast big sweepers with out it.The new dunford set up has a ton of steering in it as well Cheers!!
BmainStar is offline
Old 09-01-2013, 01:39 PM
  #5125
Got it. I think I'm set up like that currently, but will check tonight.
My biggest issue with the steering on the 2.0 is the ackerman screws keep backing out of the bellcrank. I've had 2 DNF's in the past month as a result. I just picked up the ST aluminum version and will use some blue locktite on these. Hopefully it helps. In either event, I've broken 3-4 things on this truck already and I've only been racing it for 2 months.
Anyone else finding certain parts (outside of the ackerman issue mentioned) of this truck to be fragile? Specially the CV coupler set up for the driveshafts (I wore 2 of those out and they snapped) and the Rear Bumper (broke 2 of those already as well). I run on a big track with some large jumps, but nothing this truck wasn't designed to handle.
Old 09-01-2013, 05:15 PM
  #5126
fastchvy's Avatar
Trader Rating: 15 (100%+)
Had similiar issue last night, and it was kicking my butt. Come to find out when i built the truck i put in 1 up and 1 down in the front hing pin holders....switched everything to 0's and the truck did everything i asked of it. Just bought my second truck today, this truck is very good
fastchvy is offline
Old 09-01-2013, 05:26 PM
  #5127
are you in the wrong thread? I thought you ran something else?
Old 09-01-2013, 06:06 PM
  #5128
fastchvy's Avatar
its my kids truck
fastchvy is offline
Old 09-02-2013, 04:48 PM
  #5129
glock man's Avatar
Originally Posted by Casper
I am running the Pro-4 and Dunford is running the Pro-4HD. We are both on silver springs. Only real difference in our cars is battery location due to him running the longer motor.
Hello Casper. I want to change my setup to Hacker's new setup. I want to buy Diff oils and large bottles. Do you have any recommendations or part numbers for the diff oils?
glock man is offline
Old 09-02-2013, 05:37 PM
  #5130
Trader Rating: 120 (100%+)
If you want bigger bottles and top notch oil check out Pt racing oils.
JoeC is offline
