TLR TEN-SCTE 2.0 Kit Thread
#4456
#4457
Thanks!
#4458
Hey guys,
I am building the truck for the first time and I am having a problem with the shocks leaking from the bottom around the shaft (not even on the truck yet!!)
So the description of the shock build is not great in the manual and seems to not have a good fit, looking at the shock from the bottom I put in the black piece with the flange towards the top of the shock, the oring, then the cap....seems like something is missing!!! the shock bottoms do not screw flush with the shock body and seem to be stressed to the point of almost stripping out, and again still dont seemed sealed
Anyone have a similar problem or have any advise I would greatly appreciate it!!!
Lastly, it seems there is a extra 4 orings with the shocks, the top has the cut out bladder type oring, the collars that tread on the body have their normal orings, then there are 4 more that are not mentioned in the manual...they look like ones from the 8ight shocks that could go on the bottom but they are to big, or they could around the top of the shock, but I dont think they are supposed to....LOST!!!
I built mine 3 weeks ago with no issues.
I used the manual and this picture thread on Facebook from Horizon Hobby.
Any time I had a question, it was answered on by the description on facebook.
https://www.facebook.com/media/set/?...25.55340718934
#4459
sounds like is the exact step you are questioning,
https://www.facebook.com/photo.php?f...type=3&theater
#4461
Hey guys,
As for the top-end: In the past there have three types. Diaphrams, which seem to no longer be used, then the flat o-rings that sit inside the shock cap, and then orings that sit below the threads on the shock body. I prefer the orings on the shock body - it could be that the kit came with two types to give you options (I don't have the 2.0 kit, I converted).
You headed to ECH on Sat for the ROAR race? I can take a look at it first thing in the AM if so. Also trying to head to Mimis tonight to run there if you wanna stop by.
#4462
Sounds like he's got the small shock bottoms as well. I've heard these are still out there. You need to crank the bottoms on with wrenches - this is referenced on the tlr blog spot. There may also have been an extra baggy of shock bottoms included in the kit. The small bottoms work but you have to force them. Once on all the way they are OK
#4463
Hey guys,
http://losiracing.blogspot.com/2013/...uild-tips.html
#4464
You will want to either take a look at the TLracing blog on the build tips for the shock bottoms you have, and you will also want to contact horizon CS and tell them you need the updated shock caps for the scte 2.0 that they have in California.
#4466
#4467
how fast is a pro 4 4600 be?
#4469
