TLR TEN-SCTE 2.0 Kit Thread
#3257
Just ran my 2.0 last week at the new glen helen RC track decided to run on the 1/5 scale track i like it much better big jump , long straight away and some curves , is a loose track though unless is wet , this truck did not dissapoint , it handles well and flies great of the big jump , im running Castle 2700kv with mamba pro esc on 3s , it hauls the mail is awesome , will be running on a indoor track today so im going to switch to Novak 550 4.5 ballastic motor on 2 s see how it does , also i busted one of my front A arm on the big jump , at Glen Helen track , was my fault over shot the ramp by 10 feet , so i installed new RPM losi ten scte front arms they are quite beefy , should hold up to my driving LOL
#3258
What's a good hex tool set for cheap that'll put together the 2.0 w/ no problems
#3259
I went from a 1.0 too a 2.0 on a fairly loose track. My 1.0 is almost stock though with only carbon towers and a few durability mods. My 2.0 jumps much better and is more controllable in the air. It turns in better has less mid corner understeer and has rear more grip out of corners. I beat my PB by 0.8 of a second on my first drive with the new truck and I'm still getting faster and more consistant.
My truck has all the Tekno shafts in it and the losi tune kit, better chassis etc, trick shock pistons etc, so I see no advantage to buying a new truck when other than shock towers I can mod.
Will post pics when done unless you guys would rather I go to the 1.0 thread?
#3261
#3262
I just busted the hell outta the rear bumper and it also busted the end on the torque rod.. my fault...new triple...not enough gear...is there an aluminum end available for the torque rod?
#3263
#3265
Is that the sacrificial piece? What I mean is does that protect the chassis from getting bent?
#3269
I finished my kit and the only problem I had was on the assembly of one rear camber link. It felt very loose when screwing the turn buckle together. Sure enough, first flip and the tie rod came loose from the ball end. Now it just slides in and out. Has this happen to anyone else? What would be the best replacement? Lunsford? RPM ball ends?
#3270
