TLR TEN-SCTE 2.0 Kit Thread
#2671
And your motor wires are not plugged in all the way ....... Looks nice though .....
#2673
Is anyone else using loctite on the battery hold downs ?
#2675
well i went rounds with horizon tech.. no one has ever had this problem??.. just the 2 in wyoming i guess. was also told by tech that they dont follow rc tech much as it just a bunch a.... funny if ya want 2 talk 2 the guy that designed it this is the place... with the 2 scte they built in the tech dep. at horizon they did strip the diff. ring gear bolts and had 2 dremal them out... so if you have had problems dont feel bad the techs at horizon do 2.... so is it us them or the truck ... also side note if ya like the 22s and expect the same quality ya could be ... the scte ten comes from a dif. manufacture.. and it shows...
It's not a perfect process, but just be aware that every kit is not perfect.
The reality is that you need a little mechanical skill to be successful and consistent in this hobby. Are you really having that much of a problem with building the diffs? Or just venting?
By the way - a bolt has a nut on one end. A screw doesn't. The diff has no bolts.
http://engineerexplains.com/answr/Screw-vs-Bolt1.html
#2676
Well I got mine all built up between the last two nights. I had zero problems with the diff. screws. If no one said there was any issues with theres; I woulden't even mention that I had none! Just put a dab of the tan grease on each screw tip, and they just went right on in! LOL! The shock bottoms were a tad tight like expected. I just sprayed the threads with some (dry silicone lube.) Kinda uneventful; no big deal, no leakers, good to go! The only issue I DO HAVE is the front diff. case is rubbing in the one spot like so many others on here have mentioned! I did make sure the bearings were inserted fully!! I am undecided if I wanna pull it all apart and find out where it's hitting on the "so called high spot"; or just run the fuger!!!! and let it clear itself!....It's just the principal. Pisses me off!!!
#2678
til they touch
#2679
O'yeah, and this is not my 1st, 2nd, or even 20th RC rodeo!! If it floats,flies,or drives RC been there...done that!! Haha!
#2680
the stock wires soldered on the HobbyWing SCT Pro esc that came with it are 8" long. Are those long enough to reach across the 3656SD 4000kv motor, all mounted where they are supposed to be on the chassis?
#2681
Yes and no. It's just long enough to use them but I would like them about .5" longer to have a little slack. Also a 200mm sensor wire isn't long enough. You will need at a minimum a 230mm sensor wire for the HW SCT PRO and 540 combo.
#2683
#2684
#2685
are these wires on eBay considered high quality? http://www.ebay.com/itm/171012392966...84.m1438.l2649
http://www.amainhobbies.com/product_...FY5_Qgodfi8AlQ
Novak wire super Flex wire is also good.
http://www.amainhobbies.com/product_...et-Black-Red-6
