TLR TEN-SCTE 2.0 Kit Thread
#1621
yup... holes in tire when using traction compound=bad idea. your foams will break down in half the time. I used to always vent the tire when using CC foam along with most everyone else but always had the dead foam issue after 2 or 3 race days. After I stopped venting the tire I quickly figured out traction compounds effects on the CC foam. It seems to be much more severe on SC tires then buggy tires. I usually run on a indoor clay track so I dont have to really wash my tires, just a little more compound brushed on with a tooth brush and I'm good to go. On an outdoor track where I would actually have to use a wash bucket to clean the tires I would vent the tires and of course not use compound.
#1622
I dont remember who posted this issue besides myself but i think i figured out my problem with the diff...im a dumbass and didnt realize the gear actually SNAPS ON to the pin thats slid through the outdrive inside the diff so i will be tearing the front end down and this is pry my reason for feeling the gear mesh when turning the outdrives
Heads up to anyone else that didnt realize this....
#1623
#1624
Do all 3 diffs. run the same screws??
#1625
#1628
#1629
As I stated, we have made the choice to drop the HCP as it relates to TLR for now as the shops that should get these which are the tracks, cannot even get them. As I stated earlier, even the small shops can be part of this program if they order a certain percentage of product from us. So, if they are not part of it, that is their choice, not ours. So, talk to them. It is likely the disservice is elsewhere.
The small shop can be part of the program, the track, that is the primary issue with this program and TLR. If you choose to sell another product, that is your choice, certainly not our reasoning behind this one. I recall waiting for months to get the product I actually wanted from the store I chose to buy it from.
#1631
#1633
Might be a good idea to use a roll form tap to pre-thread the diffs. I wouldn't use a tap that cuts threads as it will just weaken the threads and lessen the amount of times you will be able to tear it down. I haven't built a kit in 21 years, and so far haven't had any issues. I still have the last kit I built btw "Kyosho Outlaw Rampage". I'm also not using any taps. I didn't even pre-thread the first diff, but I will the next 2.
Ryan you haven't commented on the counter sink issue with the chassis. This is a manufacturing flaw that should be addressed. Should new chassis's be sent out? NO!!! But might want to make this change now before the entire world thinks LOSI can't program or hire a company that can program a simple CNC drill/counter sink operation. Unless it was just a tool issue for so many runs before it was caught.
And just for grins I'm already working out in CAD/CAM a titanium shock tower for this kit along with a motor mount. For no other reason then I have large enough scrap Ti laying around the shop to do it and see the weight difference. Thought a chassis would be cool but just the stock it to expensive to even bother with it. No scraps that large laying around. I'm off to work on the 2.0 some more.
#1634
Ryan you haven't commented on the counter sink issue with the chassis. This is a manufacturing flaw that should be addressed. Should new chassis's be sent out? NO!!! But might want to make this change now before the entire world thinks LOSI can't program or hire a company that can program a simple CNC drill/counter sink issue. Unless it was just a tool issue for so many runs before it was caught.
#1635
Finished my build yesterday overall very easy only issue was 1 stripped diff screw and a small burr on the steering post that kept the bearing from sliding on light sanding fixed it. I really like the new battery tray it is a huge improvement over the 1.0 and APE tray. Track test later today will post results.
SCTE 2.0 roller is 1.5oz lighter than my kingshead, TLR,ape tray 1.0 roller.
My 2.0 is 6.09# ready to race
I still need to clean up the wiring.
