S-Workz S104 EK1 4wd Buggy
#301
Thanks Guys! Question though. I have read through th eforum and this car seems quite durable. Is there any hop ups that everyone recommends? Spare parts to have on hand? Etc?
#302
I have broken the pre updated front steering knuckles and a front cvd which was from hitting a steel fence on the back side of a bid double... Lol
#303
Sounds good. I see that this has gear diffs. Are they smooth? I am used to ball diffs and never cared much for gear diffs. Also are they sealed for tuning?
#304
What kind of surface are you running on?
#305
I will be bashing a bit , but my local track is indoors and the surface is a rubber composite sheeting with plywood ramps. The only tires that get traction are Clay compound and they wear fairly fast to me.
#306
One question I do have though. Wheels. These use 14mm hex...and everyone else uses 12mm. Do they make an adapter????
#309
I ask as I am looking at availability.....with the track I will be running one, clay tires are th eonly thing that works (Rubber track) and they wear quick. So, replacing the wheels will be frequent.
Do Durango wheels fit? They (local track/shop) handles them.
#311
Like others im looking at this car, waiting for a date on the hb car but have one of these in my a main buy list, word is they go very well here on out rough loose tracks as well, and l like the price.
#312
honestly, I have often wondered why someone does not make conversion hexes. I am sure the rango guys would love to be able to slap on 12mm rear wheels without massive modding. On the front though it can get to be difficult to maintain the proper width. The TLR22/B4/RB6 rear wheel offset is very popular, but the front offsets not so much. Even more so in 4x4. I wanted to put 12mm AE wheels on my tlr22 front, but after looking at it, I could see I would never be able to maintain the same width. Good luck and if you can make them for a good price, maybe you could sell a few.
#314
I have an 8-axis table top mill. I was just looking at modifying the stock ones so they would fit into a readily available wheel. I may have to bore the center of the wheel out to accept the larger center though. A handy dandy reamer would work nicely for that.
