Team Associated B4.2 Thread >
Like Tree4Likes
Old 11-11-2013 | 01:27 PM
  #11101
Originally Posted by Matt Trimmings
2 hole are molded out of a stiffer plastic. The hinge pin hole is also drilled and not molded making it have less slop. The 3 hole is molded out of the newer plastic and the hinge pin hole is incorporated into that mold. You will notice a difference when installing the 2vs3 hole blocks on the car on how tight the hinge pin goes in.
Isn't the holes on the caster block in a different location?
Jonathan Paulk is offline
Old 11-11-2013 | 01:35 PM
  #11102
Jake S's Avatar
not in the caster block, it just removed the outer most hole.
Jake S is offline
Old 11-11-2013 | 02:09 PM
  #11103
Matt Trimmings's Avatar
No
The 2 hole was out first, so they just added an outer most hole with the 3. But, yes.
Matt Trimmings is offline
Old 11-11-2013 | 02:12 PM
  #11104
Tyler Keel's Avatar
No
If you're still running TLR your points are erroneous.
TK
Tyler Keel is offline
Old 11-11-2013 | 02:39 PM
  #11105
racer1812's Avatar
Super Moderator
TK
If he's wrong then correct his statement.
racer1812 is offline
Old 11-11-2013 | 02:47 PM
  #11106
Wild Cherry's Avatar
Tech Legend
Default A dream last night .....
Was wrenching on a B5 on Christmas morning ...
Ho Ho Ho
Wild Cherry is offline
Old 11-11-2013 | 03:00 PM
  #11107
Wildcat1971's Avatar
TK
lol, I assume this was a joke, lol. What car he is currently running has no impact on the number of holes and the history behind it.
Wildcat1971 is offline
Old 11-11-2013 | 06:40 PM
  #11108
The two hole you can also adjust the caster block height.
msandman is offline
Old 11-11-2013 | 06:55 PM
  #11109
Autocratic's Avatar
There is no caster block height adjustment. If you have the older non-hex steering blocks you can adjust the steering block height, but not the hex blocks.
Autocratic is offline
Old 11-11-2013 | 07:11 PM
  #11110
Tech Legend
You may mean the steering knuckle ?
It can be raise or lowered by adjusting the .030 shims .
Caster blocks come in 20,25 & 30 degree caster....
Gt2 & T4 used the 3 hole 30 degree
Old 11-11-2013 | 07:34 PM
  #11111
Jake S's Avatar
with the stock hex steering block without dremel there is no height adjustment on any AE caster block.
Jake S is offline
Old 11-11-2013 | 07:40 PM
  #11112
lodhammerdin's Avatar
TK
Dont be an ass-hat to Matt, he's a great guy and a fellow veteran like myself.
Happy veterans day Matt, thanks for your service buddy!
lodhammerdin is offline
Old 11-11-2013 | 08:43 PM
  #11113
Tech Legend
whoops
sorry
forgot bout hex's knuckle fit inside the block ...
Old 11-11-2013 | 09:23 PM
  #11114
Cridd's Avatar
Anybody see the team drivers running 4.2 lately or are they still running conversion.
Cridd is offline
Old 11-11-2013 | 09:27 PM
  #11115
Jake S's Avatar
think they are all running c4.2, i highly believe this is to learn for an associated MM car, or b5.wtf
Jake S is offline
