Team Associated B4.2 Thread >
Like Tree4Likes
Old 08-07-2013 | 03:11 PM
  #7786
I run 1 thin pad between the shorty and esc. I have my ESC mounted on the chassis, not on the t plate. I also like the weight centered forward like this. My ESC has never moved or been damaged running it this way. 1 thin pad is good enough.
If you want to build a stop I think the easiest way would be to modify the battery brace maybe drill a screw and a nut through it for a stop or add a stick weight to the rear of the brace. I was going to play with that but didnt need too.
chevmaro is offline
Old 08-07-2013 | 03:56 PM
  #7787
hey guys. im having trouble getting my diff together. the axle sprockets that stick out of the diff for the drive of the rear wheels doesn't fit properly. one side slots in nicely into the ball bearing but the other side doesn't fit. it's like tha sprocket is a touch too big to geth through the hole. is it a wrong part with teh car? or should i sand it down as there may be too much paint on it from the factory?
AUSBamBam is offline
Old 08-07-2013 | 04:05 PM
  #7788
Jmuck69's Avatar
New Avid servo mounts available for sale.
http://www.avidrc.com/product/5/acce...cessories.html
Jmuck69 is offline
Old 08-07-2013 | 04:07 PM
  #7789
Jmuck69's Avatar
New Avid +5mm motor centering kit is now available for purchase!
Jmuck69 is offline
Old 08-07-2013 | 04:12 PM
  #7790
Jmuck69's Avatar
Avid ESC tray now available with either steel or titanium standoffs or available with no standoffs to mount lower. Slide the tray forward for high-bite tracks and backwards for low-bite/blown out tracks.
Jmuck69 is offline
Old 08-07-2013 | 04:36 PM
  #7791
http://www.teamassociated.com/C4.2/?...gust+7%2C+2013
Centro C4.2 conversion kit through TA
ALIEN3T is offline
Old 08-07-2013 | 04:51 PM
  #7792
littlevette's Avatar
so what does that mean? no new buggy for the worlds?
littlevette is offline
Old 08-07-2013 | 04:56 PM
  #7793
Exactly.
Rfury is offline
Old 08-07-2013 | 05:02 PM
  #7794
skrichter's Avatar
Why aluminum shaft? What about steel for mod racing?
skrichter is offline
Old 08-07-2013 | 05:07 PM
  #7795
elex300's Avatar
Originally Posted by Rfury
Exactly.
The top AE drivers will be running them at the Worlds but thats it.
elex300 is offline
Old 08-07-2013 | 05:10 PM
  #7796
That is probably due to lack of availability more than anything.
Rfury is offline
Old 08-07-2013 | 05:22 PM
  #7797
Jmuck69's Avatar
Aluminum will work in mod as well.
Jmuck69 is offline
Old 08-07-2013 | 06:04 PM
  #7798
Skillz_B's Avatar
I just dont see MM as the next big thing, but more of a use it when you need it option. For decades RM has been the standard, and its not like MM is anything new. How many tracks have such high grip you cant run a B4.2? Sugared tracks, carpet tracks, maybe some clay tracks? Looks to me like AE decided to carry the Centro instead of making their own.
Skillz_B is offline
Old 08-07-2013 | 06:09 PM
  #7799
tedstryker's Avatar
placed my order..
tedstryker is offline
Old 08-07-2013 | 06:10 PM
  #7800
Wildcat1971's Avatar
I am not suprised. they were already partnered with centro
Wildcat1971 is offline
