Team Associated B4.2 Thread >
Like Tree4Likes
Old 03-10-2013 | 08:47 PM
  #2596
Matt Trimmings's Avatar
Originally Posted by WILDWILLIE 9
Why do you have to grind the towers to fit, what is the difference?
The big bore shocks are bigger around than the v2 shocks, so they would rub on the tower if you didnt space them out further or remove some material.
Matt Trimmings is offline
Old 03-10-2013 | 08:57 PM
  #2597
Cridd's Avatar
when we started racing in December seemed like our tires lasted and would not wear out. Now every race we are wearing them pretty quick. Is it better and harder driving or something i should look at in the car?
Cridd is offline
Old 03-10-2013 | 09:00 PM
  #2598
Could be the surface coming in and getting more abrasive. I would ask around and see if others tires are wearing as quick as well.
Old 03-10-2013 | 09:22 PM
  #2599
t0p_sh0tta's Avatar
Agreed, it might be time to go to the next harder compound.
t0p_sh0tta is offline
Old 03-10-2013 | 09:29 PM
  #2600
Tradin Paint's Avatar
If your driving and setup has gotten better your probably on the throttle more which may account for some of it
Tradin Paint is offline
Old 03-10-2013 | 09:40 PM
  #2601
jbrooks39's Avatar
Originally Posted by Matt Trimmings
Nope. Well that is true also but you cannot put your esc in the battery tray at any roar sanctioned race. That area must be able to fit a full size pack at any time, not a hold on let me just move this out of the way thing.
Matt
Can you show where this ROAR rule is stipulated?
Been a discussion point between some friends and I; I would like to be able to show them the documented rule.
Thanks,
Joe
jbrooks39 is offline
Old 03-10-2013 | 09:49 PM
  #2602
Originally Posted by jbrooks39
Matt
Thanks,
Joe
If you continue to read the rest of that discussion you will see that i looked in the roar rulebook and wasnt able to find anything about it. But i do remember hearing from some that they were told to move their speedo out of the battery tray, and that the only thing allowed in there was actually the battery....i guess some got through tech with it so it just depended on who teched you, lol.
Old 03-10-2013 | 09:57 PM
  #2603
Matt
Thanks,
Joe
The spirit of the rule is something like this....
You can't build a car that forces the consumer to have to use a specific brand / type of battery. The car must be able to support X battery size.
I was told that this came about a few years back due to a 12th scale car that was designed to use only specific batteries. So if you wanted to run that car, you had to also run those batteries. This rule basically prevents AE from making a car that only supports batteries that are X size and then have Reedy make those batteries. Then they corner the market on those packs until the other companies offer a new battery to compete.
So while I'm not sure how it's worded, I believe that's the reason for any such rule and the thought process involved.
Bob Barry is offline
Old 03-10-2013 | 10:02 PM
  #2604
jbrooks39's Avatar
The context of the speed control in the battery tray is what piqued my interest.
I was searching the thread for "shorty" information and came across the post I quoted; I didn't much further and figured I would ask.
Thanks for the information.
Old 03-10-2013 | 10:04 PM
  #2605
jbrooks39's Avatar
So, all things being said about shorty batteries and not being able to run the speed control in the battery tray/slot, are many racers using the shorty batteries? And more specifically, are they using them on outdoor, large, loose dirt type tracks? Or are they sticking with full packs for those types of tracks?
I should add this is for 2WD Mod.
Thanks in advance.
Joe
Old 03-10-2013 | 10:08 PM
  #2606
Thanks in advance.
Joe
For 2wd mod i would recommend a full size pack such as the wolfpack...especially on an outdoor loose dirt type of track i dont see the light weight of a shorty being beneficial, if anything it would hurt it. I would stick with the wolfpack at a minimum. Bur what Bob said is the main reason behind this shorty only car rule.
Old 03-10-2013 | 10:11 PM
  #2607
Here is the article that LiveRC did on the rule when ROAR released info about it.
http://www.liverc.com/news/special_f..._chassis_rule/
Old 03-10-2013 | 10:12 PM
  #2608
jbrooks39's Avatar
MUCH appreciated! Thank you, Matt!
Old 03-10-2013 | 10:14 PM
  #2609
No problem, it looks like you can mount your esc in the tray with servo tape or velcro...but you cant bolt anything into the battery tray.
Old 03-11-2013 | 08:04 AM
  #2610
Wildcat1971's Avatar
Meh, had a pretty rough time at the track this weekend. I need to know what changes you would do during the practice lap to make the car better. My track changes greatly from heat to heat. After, my practice time, I picked my tires for the first heat. Well it was off, they didnt blow off the track and the line was narrow. So i had some fast laps and some slow laps, but overall was ok. The second round same, and I was hoping for more consistent traction because they blew it off. But the buggy was too loose and I put down some not so great laps. Again, I was not sure what to do for the mains. It is always way different in the mains, because the sun goes down and traction comes up. I did 2-3 practice laps, and i knew I had too much rear traction. I was having real issues with the 4x 180 degree turns. The rear would not come around as I wanted and thus pulled my worst lap times of the day. So again, when you do you practice laps, what changes would you make to adjust rear traction. Ride height? Tires? I am not sure i would have enough time for a tire change. I must say, racing on a constantly changing track is challenging. But I usually know after 1 practice lap, how this will go. Just need to make that quick adjustment. For me it is normally to much or too little traction in the rear.
Wildcat1971 is offline
