Losi VS. AE Shock Oil???
#17
I've had the most consistant results that are easier to dial in with PTRC fluids. Sometimes I feel like Ae and Losi fluids are bottled wrong. (30 in a 40 bottle etc. etc.)
(CST)
(CST)
#18
Im running Losi fluid in my bomber oval car and stock SC10.
The Losi fluid is a little more higher quality than the AE fluid.
The losi fluid doesnt leak out as fast as the AE fluid but it still leaks and is the same consistency.
I filled my bomber gear diff with 50,00wt losi diff fluid and it hasnt leaked out yet. Any gear diff will leak thou, unless you use Associated green slime.
#20
Also, if the oil was dark when you changed it that means it was dirty. Happens to all shocks over time.
