Tekno SCT410 Thread
Raced lastnight with the SCT410, and a buddy of mine just finished his too. We did a swap at the end of the A-main... That 540 Pro 4 4600 is holy crap fast!! I can't believe how much bottom end he has compaired to my 550 2 pole Viper.
On a positive note... Got rid of the Deans plugs and soldered 5mm posts. No unsoldering issues to speak of.
What servo horn fits best. A lot of them require shims to be used. Which is high and long enough? For example the Losi 22 horn isn't high and long enough.
The deans aren't unuseable in 4wd sct, they just have more resistance than bullets. If you want maximum flow, bullets are the way to go. But i agree, if drivetrain is free and solder joints are solid, then it must be something in the esc or motor. Ask anybody and they'll tell you 2s high Kv setups with 6-7lb running weights will cause electronics strain and high amps being pulled.
Deans is .000090 ohms
4 mm bullet is .000250
Exactly. I only switched to the EC5 plugs because the Deans would come unplugged on bad crashes and I got tired of zip tying them. After switching however I have noticed a real drop in temperature on the battery wires and the plugs stay noticabley cooler then the Deans.
This is why we need 6500 mah 90c batteries for our 2 cell battery powered trucks but still get less runtime that our 4s powered eBuggies using 4500 mah batteries.
The problem seems that ROAR intended 4x4 SCT to be more like the light weight 2wd truck (kind of like the SC10 4x4 & slash) but the racers seem to prefer 1/8 buggy scale trucks. So we're limited to running 2s where we should really have 3s or 4s setups.
Anybody ever have issues where the ESC is cool, motor is warm and pinion is burning hot only after a couple of passes? 200-300ft total time running?
I know if ESC is cool but motor is hot it usually means your under-geared (I think) as the motor is running really high RPM's. Maybe this is happening but the heat is getting stored in the pinion? Maybe the motor bearing next to the pinion is going bad?
Tech Legend
I have also noticed temps higher in the pinion when using a metal spur.
Are you using a metal spur?
@Cain.. That sucks on the setup sheet.. BUT I think your spot on in regards to my mesh issue.. I'll keep playing with it until I get it right and youtube on proper mesh setting techniques.. I thought I knew how to do it but I guess I had no idea lol..
I run the 4300, my setup as follows on high bite. 60% current limit, 10% neutral width, 75% brake strength, 0 timing, 0 drag, 0 push, 0 reverse speed, BL/FW. Current limit is the big thing with batteries being puffed. Lately on outdoor loose conditions I'm running my current limit at 35%, makes it very controllable and less wheel spin. Braking hard is something to take into consideration as it can heat your motor up very quick, also my brake strength is at 75% on esc and down to 60% or less in my brake EPA on my TX, I run the trinity sting extreme 7200mah 90c battery with not one sign of puffing in months, I also run the thunder power 6000mah 65c bullet battery with no signs of puffing either, and I've ran those for almost a year now.......don't be afraid to drop the current limit down far, it only controls the initial punch (low end), I've notice going lower ie. 35% has made the power band very smooth, I'm thinking about going to 10% on loose conditions and see how smooth it gets, I was very worried about going to 35% but let me tell you it was awesome and allowed all the power to get to the ground with out trying to throw rooster tails lol......hope this helps
Those batteries I mentioned, you won't be close to cutoff in a 5min qualifier. The 7200 I'm still not to cutoff after a 10 min main with a few practice laps. Also a good idea to run a new battery for a few min then back on the charge and balance a few times to break it in. I won't let mine get lower then 3.8 a cell for the first 5+ runs
I haven't had the nose dive anymore since the rear red springs, battery mod, and fioroni pistons. Even when I did have the nose dive prior, with the higher current limit it wouldn't bring it up, it just kept it from going farther into a lawn dart
