Tekno SCT410 Thread
Before I get too much further (rear end done) - I have a question on the sound of the gearboxes. I used the shims as called for in the addendum etc. the instructions say they should run freely and should be smooth with no binding. They feel mechanical - I can feel the gears meshing, but I wouldn't call it rough. There is some gear sound too, but not what I'd call grinding. Having never built one, any guidance on how much noise and what kind of feel is appropriate?
If I need to pull it all apart, I'd rather know now!
Edit : sounds like a video I'm not allowed to post that I found on YouTube so I guess I'm ok.
| + YouTube Video | |
Yes, the Green Slime is a Losi Oring lube that you should be using to lube the Orings before installing them in the shock.
Actually there's a good video on Youtube of a guy building the SCT410 shocks for a friend that was having leaking issue. I built mine while watching vid and no issues yet with them.
I use automotive axle grease on the o-rings and they never leak. When installing the shaft loosen up the retaining collar at the bottom of the shock so it does not compress the o-rings then tighten it back up after you install the shaft. Make sure your shafts are not scratched up, have you been running your shock boots? If they are marked up get new shafts.
Paul
Paul
I'm running his setup with the stock pistons for now until I can get my hands on some Fioroni's. The setup works pretty well on a high bite, indoor clay track, but it's a bit stiff through the bumpy sections. The Fioroni pistons are the only thing that's keeping me from having his exact setup.
When I first built the truck I started with 7-10-5. I've had 3 track days on the truck, so I think it's time for a diff rebuild anyways. I'm gonna try the 10-10-5 setup. Do you think the diff whip is coming from the front then? The only time I get really bad whip is on switchback sections of the track.
May be worth new o rings.
The point to inserting the shaft with the cap loose is to avoid tearing the o ring. Doing it again with the cap loose may not help if the o ring is already damaged.
hard to say with out seeing it. just my opinion with out seeing it i would suggest taking out some droop first and or stiffening the sway bars. this is just my opinion/suggestion and i'm sure someone else will have a different one. take video of it doing it if can, so much easier to see whats going on
That's good stuff to know bud. Just got the Tekno kit from the UPS guy. And the MMP SCT will be in tomorrow. My local track does have a 2s limit in 4x4 SC racing. But I hadn't planned on really racing it with my crappy work schedule. It'd just be some "friendly" races when i manage to get out there for some fun :-) Thanks again though. I'm definitely happy to hear positive things considering the immense amount of BEC issues I keep hearing about regarding the MMP. Although it seems to only happen with certain electronic combos.
Howdy,
I'm building this truck (first build) and this is all going swimmingly. UNTIL...the rear camber links/turnbuckles. I absolutely cannot get the metal part to thread into the plastic link. I have tried turning in one direction, and then the other. I have gotten one on, but after repeated attempts the other 3 just won't cooperate. I realize the turnbuckle is left and right threaded, but knowing this doesn't seem to help. Tips please! I hoping to complete this build today so I can wire it up before the weekend!
Thanks - DB
Thanks - DB
You must build them with bladders. The cap has a vent hole in it, so emulsion is out of the question. Use the Tekno bladders, they work great. No compensators, they will give way too much rebound, and the bladders do not need the support.
17Likes
