Tekno SCT410 Thread
#7666
I used to be a (major name) tool dealer, they would make a batch of 10 mm sockets that got heat treated wrong (too hard), and I would go from changing out 3-4 a week to like 20 a DAY when it happened. About every 18 months it would happen, I'd change sockets like mad in one size till we worked our way through the inventory cause it's not like you can look at them and say "that one's no good" unless somebody tried it.
If they are taking care of it, I'd order one extra and just break away.
#7668
Its been finished, just done a little remapping with the electronics Your times a comin Yank.....
#7669
Tech Legend
bear in mind the warranty policy with the Brushless hobbies ESC.
You could try AE silver 3.9lb springs. Those are what i am using up front.
have you tried drilling a hole in the stock plastic hexes and then adding a set screw. You can then keep your hexes on the axles.
#7670
Ok, after seeing this post http://www.rctech.net/forum/11988022-post2716.html, i'm pretty sure it's not the motor that's low on grunt. Rcphreak, i'll try what you suggested and get 1 smc race forumula pack, if that fixes the problem, i'll order more. I can't be the one guy that got a gutless motor, it has to be something else. About 80% sure it's my season old nano's.
#7671
my tekno goods
sct410 with proline toyota tundra body, aka ss enduros, rx8/pro4 4600 and hitec 7955tg
eb48 with all options, durango low pro wing, aka ss i beams, rx8/1900kv t8 and savox sb-2273
#7673
Bad batch it happens. Its how its taken care of, and Tekno took care of it first class. Replacing broke ones asap, and its hard to pin point what ones are "bad".
I have clipped pipes, cartwheeled, barrelrolled, u name it. No issue, never broke a thing.
Strongest truck out there period. IMO
#7674
I have no complaints with this truck even though I broke an axle on my first outing. Was just advising the issue. I've had a lot of experience with other brands and broken more expensive parts. One brands stock chassis would bend very easy. I wouldn't trade this truck for any of the others. I recommend it. 6 guys at my track have switched from a popular brand to the Tekno and I'm the only one who has broken anything. If you are on the fence, this truck drives great, like a 1/8 buggy and I have no doubtTekno will fix this issue soon if not already. Awesome product.
#7675
No Cain I have not tried that (or thought of it ) I will give that a shot until the Aluminum ones come in. I found a set at Tower Hobbies that are 6mm and should work with possible a bit of grinding.
#7676
#7677
i deffinatly need one of these trucks not i gotta sell my e buggy... haha its a hot bodies
#7678
I had a converted D8 and it railed ! Didn't quite turn as quick as the EB48 and was much heavier but was still very fast .....
#7679
Can't comment on the MMP in the tekno specifically, but, in the SC10 4x4 from what I have read and what I saw briefly before taking it out of my previous sc10 4x4 was that its stock BEC was not up to the task with high power servos and high power motors on 2S.
Loved the ESC in my 1/8 vehicles on 4S, but got cogging, etc. instantly when I put it in my SC10 4x4.
I have read those who do use it, you pretty much need the external BEC. it works then though it won' deliver power like the RX8.
For me, the Speed Passion GT2.0 ESC has been working excellent for 2 pole 550 and 4 Pole 540 motors I have tried. Love its size as well in my Tekno.
#7680
3 place finish in the B main at rjd hobbies tonite the entire pro class was fast less then 2 laps across the entire field to the TQ almost bumped up it was a close fun race and very clean and fast ..... missed bumping with one mistake with 30 seconds left o well there is always next week finally getting were I need to be to really race this truck ...this driver needed a tune up after driving my sc10 4x4
