Tekno SCT410 Thread
#7562
I am thinking about getting the tekno so...
how much do they weight fully lloaded?
what motor are you guys running?
what tires for hard packed dirt? rebars?
thanks
thanks
#7563
I've owned several sc10 4x4's the FT kit is really great, and to me had way more steering then anything I've ever driven. I got out of 4x4's for awhile to concentrate on 2wd buggy, but decided to give it another try so I can't wait to get my sct410 and see for myself the difference between the two (even from an scte 1.0 I've also owned in the past). I've talked to several users on here via pm about the sct410 (especially Cain) about the diff. between the two 4x4's and so far I am happy I made the decision to purchase the tekno over the losi scte 2.0, and hopefully I'll be just as happy when I build it and run it at the track.
thanks guys-
#7564
Stealth won the main by 2laps and I was second with my Losi.... it defaintely has me thinking time to switch platforms... LOL
#7566
#7568
Ive just purchased the Tekno SCT410 from Tower today. Im excited to run it. I plan on running box stock. Any parts I should stock up on? Any build tips and mods? I read about 20 pages back then got bored .
Running on a large loose/dusty track suited for 8th scale usually, so the weight of the truck will help. RX8 and Pro 4600 until the HD Pro4 comes out.
#7569
#7571
rx8 help
I run a tekno sct with a rx8 and tekin 4600 with a 15 tooth pinon my motor is 155 after 6 minutes with min timing on rx8 how can I lower the motor temp
#7572
Can't speak to your gearing being correct or a tooth high but you can limit current to 80 (hotwire) or less, that should pull temps down a bit. But the pro4 is fine up to 180 so your well within range (per tekin). Most like to keep it below 160, but you don't start destroying things till well over 180.
Most seem to see lower motor temps with the tekno, curious if your gearing is correct or not or maybe there's drag somewhere? Bearing? Somethings rubbing?
#7573
No dragging in drive line I geared down a tooth and only dropped temp by 10 degrees
#7574
#7575
Looks like your in the range for gearing at a medium track, where does your track size fit in here?
Small track (50-100 ft straight)
3600-4000 kv 13-15 tooth pinion
4400-4800 kv 12-14 tooth pinion
5000-5400 kv 11-13 tooth pinion
Medium track (100-150 ft straight)
3600-4000 kv 15-17 tooth pinion
4400-4800 kv 14-16 tooth pinion
5000-5400 kv 13-15 tooth pinion
Large track (150-200 ft straight)
3600-4000 kv 16-18 tooth pinion
4400-4800 kv 15-17 tooth pinion
5000-5400 kv 14-16 tooth pinion
