Who uses a Turnigy Trackstar SCT 550 can motor?
#31
Well, I was hoping to try one of these in my SCT and would have posted results...but wouldn't ya know it. My order apparently got lost. Worst part is UPS tracking "shows" that they did actually deliver it, so I may be completely SOL. :flaming
#32
Yeah, they have to make one stop. But it takes 10 seconds. If I can get the run time sorted out, I'll make a stop and go just to keep things even. I pitted for a battery swap and it took a minute, easy. Felt like forever though...
The one thing that makes me wish I had just sprung for the RX8 is the current limiter. Not sure why everybody doesn't implement one. My buddy's SCTE, granted it is lighter, but he is set on something like 65% and it still runs hard with a Rev Tech 4800 and he gets plenty of run time. Well, he's upside down more than me, so maybe that is the biggest difference
#33
Good news, UPS has located and delivered my package. I should be trying out the 4.0T tonight.
#34
wow... I had no idea. Why would they call it current limiter? It certainly implies something else... or maybe I was given that impression by my friends that run one and really have no idea what it does...
derp.
#37
A few things first.
In this vid, I am the green truck. This is an 1/8 AE 8.2/Tekno converted, further converted with SNR Graphite Towers and TBone Racing bumpers to run 4w Mod SC. Bottom line, it is a tank. I havn't scaled it though I am thinking of picking up a postal scale just for gits n shiggles. That said, I guarantee it is heavier than your "standard" 4w SC. I am guessing 7+ Lbs.
In this vid, I am running Turnigy Nano soft pack 45c batts which have seen better days, with a Tekin SC4X 4.5T. I could make the back jump if I really timed it well, but it was difficult to do consistently. I am also running 15/44 gears.
Tonight I ran the Turnigy 4.0 with new 65c Nanos and I played with gearing, settling on 14/44. After a 6 min qual, batt, motor, and ESC were quite warm. After the 8 min main, on the verge of egg frying. That said, power was awesome. I could clear the back jump with no difficulty, and could do it consistently lap after lap.
I am not going to continue to run this set up as it is too taxing...but I am hoping to be able to pick up the Tekno SC once it is released. I would bet that it would run fine in that as it is reported to be down around 6 Lbs. The one thing I havn't yet tried is running the SC4X on the new 65c batts. I'll probably do that on Sunday. With the 45c older batts, everything was noticeably cooler, and though I couldn't clear the big jump consistently, my lap times did not suffer as I TQ'd with this set up this past Tues.
+ YouTube Video | |
#39
I have two of them, a 5.5 and a 5.0 SCT 550. Happy with both, but I did have a magnet come loose from the shaft on one. It was an easy repair, just a little metal to metal high heat epoxy from the auto parts store and back on the track and many packs through it since. There's more detail about it I posted, check my post history if you're curious. I'm still using and very happy with the performance of both.
#41
I had the 4T(5120Kv) motor on my SCTE and worked great with the HK 150A ESC, then I switched to an RX8 and the motor started to get hotter (around 170ish) Theeeeeeen I got a tekno sct410 and the last time I raced that motor, after a 8min amain.... motor quit running. After I check the temp, it was at a whooping 279 degrees. I melted the insides of it. Moral of the story; do not use this motor in a heavy sct truck lol.
