The AE FActory Team B44.2 Thread
#3211
Made a custom mini torque wrench for measuring diff tension. Some rc company should make something like this. You can buy ultra sensitive screw drivers with torque displays, but their $250+.
There went an afternoon!
+ YouTube Video | |
#3213
#3215
All put together. Having a couple issues with it though. The first thing is electronic related, speedo sensor board bad. Any way to fix this on a Novak pulse, other than sending it in? The second is the front cvds. I have the included silver washer on the ball stud and one limiter in the shock. Here is the problem. It is like this on both sides. Both sides are built identical.
The last thing is that one of the shocks. The shock bottom cap does not go over the o ring.
Not sure why,the rest are perfect.
For the guys using rpm ball cups I used the long ones other than on the steering links. Make sure that you go through your kit completely before starting the build. I had a few parts missing that I had to run to the hobby shop for. Other than some minor things the kit went together smooth and I am very happy with it. The savox 1251 low pro servo needed no shaving to get it to fit. I want to send out a big thanks to un4racing again for the videos. I used them as a video manual and barely had to refer to the actual one. Thank you sir!
#3216
In regard to the front cvds, what has most likely happened is you don't have the shock eyelets screwed onto the shaft all the way. The front shafts are 21mm stroke and the rear shafts are 27.5mm stroke. With one limiter installed, which is just under 1mm, the exposed shaft between the bottom of the shaft and the shock eyelet should measure around 20.9mm front and 26.6mm rear. If it is very far off from that, you should see if you can screw the ends on more. This is a common problem with the new big bore shafts--used to be that you screwed the eyelets on until the stopped just a little or else you would strip them, but the new shafts and eyelets are much tighter and it tricks you into not threading them on all the way.
#3217
#3218
#3219
I am going to be running a 7.5 so I built some new gear boxes for the heck of it and to run a looser shim set up. This is how dirty one long out drive was... Ick! It all came from the inside of the long end where the diff nut and spring fit in. I want to pop open the new set I have on the kit any hoot. 1st night out it was making some noise. But quit after 5 packs.
Dirty sucker.
Dirty sucker.
#3220
For your shock cap: check to see if you didn't put one of the plastic part upside down ( the little washer-like parts on top and bottom of the oring ). One of those washer-like part is very easy to install upside-down.
Okay... my explanation isn't the greatest but I'm just about to leave for work and also English isn't my first language
Check page 18 of your manual, part number 91309...
#3221
Both should be installed with their flat sides against the o-rings.
#3222
