The AE FActory Team B44.2 Thread
#1726
If your using gold barcodes then you will want the clay compounds most likely.talk to guys at the track, someone there probably already has it figured out.
#1727
so far so good, no problem at all.
http://www.amainhobbies.com/product_...-Spring-Cups-4
#1728
Question on the Aka rebars front and back...
Race on a indoor packed dirt (clayish) med to high bite where jconcept bar codes Gold and losi pinks hook up pretty good.
What compound should I get?? AKA Super soft be too soft or wait for the new clay compound? I have pretty good throttle control but sometimes I get trigger happy out of corners.
Should I try super soft?
Even a jconcepts green? Or are these compounds made for dryer tracks?
Just looking for tire before my kit arrives.
Our track is Medium traction most of the time. I run super soft on all fours and with 4 1/8th holes in the tire and red inserts. They last much longer than any other tire on the market.
#1729
Suspended
Our dirt sounds the same. Its top soil, the rebars are the best at out track and dominate the field. When the traction is real high a soft in the front and a super soft rear. The red inserts are a must. I would recommend no holes in the tire but 2 in the wheel. This will make the tire stiffer but if its to stiff you can add 2 hole at a time to the tire as needed to soften them up.
#1734
Awesome looking!
What camber links are you using? Those look really good on this car.
Looking forward to your race report!
#1735
used hartson's setup last night except i ran short wheelbase and my car was the best it has ever been. Very consistant and a blast to drive. that run got me TQ!
love this car!!!
love this car!!!
#1736
how muck longer is this then a .1 car?
#1738
http://www.jconcepts.net/store/index...products_id=23
#1739
8mm Longer.
UN4RACING- Nice car! It looks dialed with the lid on it. Very stealth. I think it's funny that you say Rebars last are a long lasting tire though. I got some used with a kit I bought and they appeared to be almost new. They were awesome on the dusty outdoor track I used them on, but by the end of the day the middle of the tire was slick. I'm fairly sure they were super softs, so it could have just been that it was too soft of a tire for the surface I was running on, but they were hooked up, so I didn't care. Good luck in your race today!
