Kyosho Ultima RB6 & RB6.6 Car Thread
What size pinion should I be running with a 10.5 T motor and 75t spur?
Anybody running the Avid Springs? I was thinking about buying the package deal for both front and rear but a lot of times you end up paying for Springs that are either way to stiff or soft.
http://www.amain.com/avid-rc-12mm-ba...-set-4/p241347
http://www.amain.com/avid-rc-12mm-ba...-set-3/p241348
Need Help Quick
Hey guys... at a race and bent a rear shock shaft. The shop doesn't carry kyosho parts... are there any other shafts that will work on the rb6?
Any help with this would be great.
Cheers
Rich
Thanks for the reply. The AE one didn't work either... It's 3.06mm thick. Probably could have made it work by reaming out the o-ring spacer but I ended up bending the original shaft back and crossed my fingers. New Kyosho shafts are on the way... Along with some spares. Oddly enough another RB6 bent his rear shaft yesterday too. Wasn't the cars fault. Can't speak for the other guy but I got hung up sideways on a pipe... another car overshot the jump and did a nose dive between my tire and wing landing directly on the shock.
I'm using the Zack Rogers setup but have the older style MMR suspension hangers. I have both the wide and narrow versions (from Exotek) but which do you guys recommend?
i have bent the reears as well so i just carry a spare set of full shocks. oddly mine also bend at relaviely soft hits. this in mm rm i never had a problem.
So what's the more popular choice for speedo placement in a mid motor? Speedo in front of the battery with battery all the back or speedo in back of battery with battery pushed foward?? Running the car on medium bite clay in mod.
