Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 02-17-2014, 02:24 AM
  #9871
Hi all
Not sure if this had been asked before, but what parts do I need to convert the front hexes to AE bearing weheels, as all my 2wd are on the bearing wheels, so made more sense for me to share the front wheels.
viktozzz is offline
Old 02-17-2014, 05:42 AM
  #9872
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Originally Posted by viktozzz
Hi all
Kyosho is metric and AE is standard. It will be hard to make one fit but nothing is impossible. That is one of the hurdles that you have to clear.
Kraig is offline
Old 02-17-2014, 06:37 AM
  #9873
Hi all
Try the Bmax2 MR front axle. I remember for it to use AE front bearing wheels all I needed was a different sized bearing
zzztech is offline
Old 02-17-2014, 08:38 AM
  #9874
MikeXray's Avatar
Trader Rating: 73 (100%+)
Had to tune for some "unique" conditions at motorama, really had to lighten up the shock package to handle the insane bumps, ran mid motor half the event, then switched to my RM car trying to put some safe runs in. Car was good, but I couldn't complete a run without crashes..
MikeXray is offline
Old 02-17-2014, 08:53 AM
  #9875
R/C Tech Elite Member
TIME MACHINE's Avatar
Trader Rating: 74 (100%+)
Will the AKA pre-mounts fit the RB6?
http://www.amainhobbies.com/product_...ounted-White-2
TIME MACHINE is offline
Old 02-17-2014, 09:57 AM
  #9876
MikeXray's Avatar
Yes, I ran evo typo clays this weekend, the fitment is the same as their old wheels, the rears need a thin wheel nut or you can get the avid long axle conversion.
MikeXray is offline
Old 02-17-2014, 04:02 PM
  #9877
thanks for all replies...
have always wanted a RB6 since i saw it in action more than a year ago... and run it in MM config..
would try if any other front axle fits in and post back here with results to share with all, as i believe that i might not be the only one with all the bearing wheels for 2wd.
viktozzz is offline
Old 02-17-2014, 04:47 PM
  #9878
i think yokomo actually makes an axle for AE wheels, so you can same bearing. your other option is a tresrey ae axle meant for the durango dex210. if you can get that to fit.
glenng is offline
Old 02-17-2014, 07:45 PM
  #9879
Anyone have trouble with the servo horn hitting the front clip on the RB6? Jus got one and trying to install my 1258tg but the horn keeps hitting. Tried two different horns and with and without spacers.
CaseyD is offline
Old 02-17-2014, 08:00 PM
  #9880
gelshocker's Avatar
Yes. I found it's KO servos that will fit. Others hit or miss (Sanwa BRX will not fit)
gelshocker is offline
Old 02-17-2014, 08:32 PM
  #9881
Trader Rating: 25 (100%+)
Tried gearing my stock buggy 33/72 same as my B4 but the gear cover is hitting the pinion. Wondering if I need a 69 spur with a 32? Or what gear can I use that will work?
chevmaro is offline
Old 02-17-2014, 09:45 PM
  #9882
losi 70 with losi slipper pads
AlwaysLOSI is offline
Old 02-17-2014, 10:08 PM
  #9883
whitrzac's Avatar
Trader Rating: 97 (100%+)
You can dremal the gear cover to fit around the 33 and 34 tooth pinions..
whitrzac is offline
Old 02-18-2014, 04:17 AM
  #9884
nickdawg18's Avatar
Trader Rating: 33 (100%+)
hitec 7955 fits perfect too.
nickdawg18 is offline
Old 02-18-2014, 04:29 AM
  #9885
Yes u r quite right!
http://www.rc-race-and-drift-japan.c...oducts_id=3591
zzztech is offline
