Kyosho Ultima RB6 & RB6.6 Car Thread
No just run different shock ends and different droop. No need to put spacers on the inside of the shock. I normally around 20 front 28 rear with shock length "B" medium front long rear shock ends.
My shock set up right now for rm is front 30w 1.3x4 pink spring 20.5 length with med end. Rear 25w 1.3x4 red rear spring 28 length with long end.
Gonna test a couple of 1.5x2 tapered and non tapered pistons, for now loving the tapers conical part facing the sky.
The longer shock ends should be used with the gulwing arms. The shape of the arm actually won't work well with the shorter shock end. You won't get enough droop. Lack of droop will make the car jump differently and not so good in the ruff.
with the shorty transverse against the motor, i used it. also have a lo pro servo, so needed more steering and it helped a lot. re-building car right now for inline shorty against motor and going back to aluminum piece.
delete problem solved.
Any one have a good low traction dirt set up for mid motor?
Try this looser style track setup
Front:
35wt Losi Oil/Losi 55 Pistons/Pink Spring/Medium Shock End Used
Outside location on tower / Outside location on arm (front shock shaft length exposed 20.5mm)
Middle on bulkhead with 1mm shim under ballstud / 1mm shim under casterblock ballstud
Casterblocks spaced in middle position on the arm
Spindle in Upper Position / No bump steer spacers used
Ackerman bar ran in standard position as in the Manual / No ball stud spacers used
Caster Inserts and RB6 Front Axles used the same as in the Manual
25 with no spacer
Rear:
27.5wt Losi Oil/Losi 55 Pistons/White Spring/Short Shock End Used
1 hole out on tower / Middle hole on RB5 arm UM521-1 (rear shock shaft length exposed was 27mm)
Outside on bulkhead with 2mm shim under ballstud / 2mm shim under ballstud in back/outside hole on .5 degree aluminum hubs
Hubs spaced in middle position on the arm
Wide plastic front and rear suspension mounts
Ride Height: 25mm front and 24mm rear
Team Orion Shorty 4000mah Battery used spaced back in standard direction with ESC located in front location by Servo.
Tires Used:
Front: AKA Super Soft 3-Ribs with Red Foam
Rear: AKA Super Soft Impacts with Red Foam
Front:
25 with no spacer
Rear:
Tires Used:
anyone know what D/in and D/in will give me for rear toe? scratch that just found the link for all the inserts
if i use the stock plastic narrow rf hanger and adjustable rr hanger what is the narrowest i can go and still have 3* toe. or better yet what does the narrow rf hanger equal to on the adjustable hanger
Anyone try the 521-1 arms lately with the new chassis?
Trader Rating: 89 (100%+)
I put all carbon LW parts on my car yesterday, crazy weight savings, towers are 3 grams less, each arm around 2.5, shaved off close to 20 plus grams! great for stock racing to reduce unsprung weight.
