Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 10-19-2013, 09:21 AM
  #8461
rpboggs1's Avatar
Trader Rating: 19 (100%+)
Originally Posted by aloksatoor
Did you check the rear suspension bind. Rear shock preload, shaft not busted or bent in one shock? The cars gotta squat symmetrically on full throttle otherwise it will be pulling. Front wheels are loose and free correct?
You're right on with the suspension. Loosened the retaining nuts but it still pulled hard left. Swapped to some old tires and gave it a few straight line rips... the left rear showed a lot more wear so its definitely digging harder on that side, causing the diff to transfer power to the right which pushes the car left. (Check my logic) Everything seems free and smooth so I'll start by bleeding the shocks again just in case.
rpboggs1 is offline
Old 10-19-2013, 09:36 AM
  #8462
Hold the rear of the car up in the air and grab some throttle. If there is a problem with the driveline it will try to torque in your hand, if the rear is in the air the suspension will have no effect.
Buckland is offline
Old 10-19-2013, 10:05 AM
  #8463
Suspended
Could someone please do me a favor and measure the front a-arms from inner to outer hinge pin? I am working on revising the front end geometry on a different 2wd buggy, and I think the RB6 front arms might be what I need.
Art_VanDelay is offline
Old 10-20-2013, 11:05 PM
  #8464
gelshocker's Avatar
Hey guys anyone have the parts list for the Kyosho RB6 titanium screw set UMW703? Thanks,
gelshocker is offline
Old 10-21-2013, 06:53 AM
  #8465
SAMCRO's Avatar
Originally Posted by cnelson3
I thought about that as well. I trimmed my battery strap so i couldn't mount my front battery cradle far enough back to get the battery strap to lock down on the motor guard. This may be something I revisit if the track gets looser but I worry about the pendulum effect it creates.
I put a shorty pack in sideways and put 2oz of weight behind it. Has been the best configuration I have tried..
SAMCRO is offline
Old 10-21-2013, 07:53 AM
  #8466
MikeXray's Avatar
Trader Rating: 73 (100%+)
Any chance you did something, like accidentally having different springs on the right vs left side?
MikeXray is offline
Old 10-21-2013, 07:11 PM
  #8467
Teufel Racing's Avatar
Trader Rating: 30 (100%+)
has anyone tried mounting the battery all the way back and the speedo in front of the battery in MM? I tried tebo's worlds set up and the back end wasn't nearly as planted as the battery behind the speedo. for clarification, you can run a shorty pack so far back it slides under the motor guard and hits the motor, but i'm not talking that far back. Just the most rearward position using both battery cradles.
I tried it today along with a 1 mm shim below the rear toe block. I'm really surprised by the results. our track gets a little slick sometimes and the mm buggy handled it well.
I currently use that ESC/Battery config as well and I think I'm just a touch heavy up front, but it seems to work pretty good. Have thought about adding a little weight in the rear for when the track isn't as high bite, but haven't yet done that. Have also been thinking of putting the R10 behind the batt simply because it's a little on the heavy side for an ESC, but will try that too later on. So far the MM setup with the front ESC config seems to work good enough for me right now, that I'll probably stay with it a little longer to see what other changes I need to play with first.
Teufel Racing is offline
Old 10-22-2013, 10:19 AM
  #8468
aloksatoor's Avatar
Trader Rating: 43 (100%+)
Also before rebuilding shocks, just swap them left right and see if the other side pulls. That means you have to rebuild the whole shock pistons/shaft/bushing/orings.
aloksatoor is offline
Old 10-22-2013, 10:22 AM
  #8469
aloksatoor's Avatar
ANyone still running the steering rack with arrow behind? It made my RM more uncontrollable. I am going back to the stock ackerman position. The high speed steering went away would break loose way before (did not change the 1.5 front camber maybe needed to do that?). The car turned the hairpins a bit better but nothing that advantageous.
Old 10-22-2013, 12:05 PM
  #8470
MikeXray's Avatar
Your toe is likely off, and that can also affect your camber, so I would say to squaring those up first, isn't the swap only like 1mm difference?
MikeXray is offline
Old 10-22-2013, 12:16 PM
  #8471
stiltskin's Avatar
Trader Rating: 103 (100%+)
What is this "steering rack mod"
stiltskin is offline
Old 10-22-2013, 12:20 PM
  #8472
MikeXray's Avatar
Mounting it backwards, moves the ballstuds back a little bit.
MikeXray is offline
Old 10-22-2013, 12:41 PM
  #8473
tef
Next time you flip the rack try moving the front C hubs back too. When Tebo flips the rack it moves the ball stud back 1.25mm, but he also moves the C hub back 1mm so he is only 0.25mm back over stock. If you don't slide the front hubs back with it you are actually 2mm longer then what JT runs which will make the car feel exactly what you are feeling, inconsistent. Keep in mind when you slide the front hubs back it will put more weight over the nose and create more overall front grip, not necessarily twitchy steering though. it creates more front grip with a less linear feeling. I used this all summer when the tracks have a lot of high bite and are not forgiving.
tef is offline
Old 10-22-2013, 02:34 PM
  #8474
aloksatoor's Avatar
Hmm that explains it gentlemen. I will check the toe and move the c hubs behind as well.
Old 10-22-2013, 07:10 PM
  #8475
Razathorn's Avatar
Jared's latest setup from the worlds has the spacer in front, but his nats setup had them in the back. Both had the ackerman backwards. I run with the spacer in the rear and the ackerman backwards and my car is amazing. I can cut out 4wds entering our straight from a corner.
If you're having trouble balancing low speed and high speed steering, might I suggest you play with camber and caster blocks. The 4 degree blocks, what I run, will give you more high speed than low speed steering. You can also bleed off steering at low speed and add more at high speed by adding more negative camber in the front. I run -1.5 in the front. Feels good man.
Razathorn is offline
