Kyosho Ultima RB6 & RB6.6 Car Thread
#6496
The JC b4 or JC TLR rears? I assume you meant B4. 3mm? are you sure, Those manufactures, like AKA, JC and others market those rears as for the b4, RB5/6 and tlr22. The main reason for the wheels nuts fitting seems to be the wheel thickness around the axle. I have some various wheels at home, but none of them have the same tire for an accurate comparison. If anyone has unmounted wheels, I would definitely like to see how the avid, aka, JC, Kyosho and other wheels measure. 3mm would greatly make the car feel different.
#6501
To his point Brandon, the JC Wheels are marketed as B4/RB5. They have a different part number for the 22.
http://www.jconcepts.net/store/index...roducts_id=535
http://www.jconcepts.net/store/index...roducts_id=536
22 - http://www.jconcepts.net/store/index...roducts_id=534
#6502
hey guys thinking of getting this car.
any weak points build tips?
#6504
hubs more than anything, i have ripped a few ballstuds out. havnt broken anything else except for bending the front pin brace
#6508
Just bought my first rb6 coming from a b4.1 and rb5 before that. Bought the exotec rear bulkhead and steering rack. Few questions... Are the rear hinge pin braces a must? some say yes and some say no. Also i have a ton of wheels and tires for a b4. I know the fronts will not work but will the rears with the pin work?
#6509
So what parts are worth stocking ? any upgrades needed? which is a good base setup or good setup is manual setup?
where is a place to get a RB6 cheap, cant find anything below $449
#6510
the best place i have found is rc champ in japan fast postage cheaper and you should be able to get all you need from them
upgrades
the new front hinge pin brace
alu hubs 0 and .5
rear springs gold & white (x-gear)
front white (x-gear)
alu rear susp hangers wide and narrow
the thing is bullet proof so just arms and towers
and you should be set
cheers
