Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 12-19-2012, 07:03 PM
  #3511
umm winning's Avatar
Double post.
umm winning is offline
Old 12-19-2012, 07:15 PM
  #3512
rcfiend's Avatar
Trader Rating: 42 (100%+)
Hey I noticed some are using 4x 55 pistons, are these the Losi 55 pistons?
rcfiend is offline
Old 12-19-2012, 07:36 PM
  #3513
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
So how many of you have strayed from the kit body and tried the others that are on the market? Just curious as to what your findings where.
Kraig is offline
Old 12-19-2012, 07:42 PM
  #3514
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Yes, they are for the TLR22.
Yeti AS3 is offline
Old 12-19-2012, 09:09 PM
  #3515
BranVita's Avatar
Trader Rating: 39 (100%+)
I already switched to the JC Finnisher. Imo, it looks alot nicer and I always liked the Finnisher body on the B4.1. As for peformace, I cant tell lol
BranVita is offline
Old 12-19-2012, 10:23 PM
  #3516
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by MIP MATT
I wasn't aware they were more expensive? .
Yeah.. going off the prices listed on your website for just a pair of outdrives, they are more than Kyosho outdrives from Amain. Unless I find somewhere else to buy them, it IS comparing retail to retail.
The MIP Diff is a complete diff not just outdrives. The only thing that you take from your old K diff is the screw and tnut assembly.
I understand, but I have no reason to buy an entire diff. It's just the outdrive wear that is making me look for an alternative. The rest of the diff is 100% flawless. If the outdrive wear is considerably better, it will be worth the initial investment. But the cost of replacing out drives after the fact needs to be measured into the equation. If outdrive wear is about the same, then it wouldn't be worth having to buy an entirely new diff as an initial investment.
You have to compare MSRP prices. So Apples to Apples MIP diff: $40 and Kyosho Diff: $55. So at A-Main or at your LHS the MIP diff will be around 30 to 35 retail.
Great... if retail price for just the outdrives are equal or less than kyosho, and wear is better, it will be a win/win.
The advantage is just that, better quality outdrives. And the kyosho RB5/6 axles are coming We are in the final test stages for you guys. Just don't want to release anything that isn't ready.
Awesome, we can't wait.
Cpt.America is offline
Old 12-19-2012, 10:29 PM
  #3517
I ran the losi 55s, but didn't like them that much (the piston itself, not the fact its a 4 hole #55). They were not all that smooth, and they don't fit in-between the two containment E-clips like they should. They click back and forth, and I didn't feel like finding that .01mm shim it would take to stabilize it. I ended up switching to the Ghea pistons and they are absolute money! .. pricey, but awesome.
Old 12-19-2012, 10:39 PM
  #3518
t8rtot's Avatar
Trader Rating: 14 (94%+)
Sizes?
t8rtot is offline
Old 12-20-2012, 01:21 AM
  #3519
mdowney's Avatar
Trader Rating: 21 (100%+)
Team drivers are using the Kyosho blank pistons and drilling out 4 holes with a 55 bit. Details and tips a few pages back. The Losi pistons don't fit that well. I prefer the GHEA tapered pistons.
Originally Posted by t8rtot
Sizes?
4-hole 1.3mm
mdowney is offline
Old 12-20-2012, 04:41 AM
  #3520
Trader Rating: 18 (100%+)
The avid's are really nice, too. I've been running the 1.6 + 1.1 4 hole pistons with pretty good results.
KSimmonds is offline
Old 12-20-2012, 07:35 AM
  #3521
Trader Rating: 125 (100%+)
So the consensus is that the 4 hole pistons are better than the kit 5 hole? What size are the 5 hole? Have blank K pistons. Is 55 bit way to go? Don't have 1.3mm bit.
kwiksi is offline
Old 12-20-2012, 07:42 AM
  #3522
John.C's Avatar
Trader Rating: 37 (100%+)
I'm getting ready to order the GHEA pistons and I have 2 questions.
1) Are these the GHEA 4x1.3 hole pistons everyone is referring to?
2) Can someone confirm that the pistons are installed with the tapered side facing down? I can't afford to make another bone headed mistake
BTW, I've been out to the track twice since my rear suspension block debacle and the buggy has been great both times. I'm still learning how to drive and jump my buggy but it's really planted and easy to drive now.
John.C is offline
Old 12-20-2012, 07:45 AM
  #3523
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
Its just like driving touring cars with bumps!!!!!!!!!!! You should be pretty dialed at The Track as it has lots of rollers and elevation changes so it is more like a touring car than your would think. I'm sure you will get the hang of it. At least you have the left and right things down.
wyd is offline
Old 12-20-2012, 07:52 AM
  #3524
yep #55 is actually slightly bigger than a 1.3mm, but its very close. (1.32mm)
Yep
yep
Old 12-20-2012, 08:06 AM
  #3525
eper's Avatar
Trader Rating: 14 (100%+)
Default shock tool
Shock tool is now available, pm me if interested they are $12 shipped. sorry about last night not having pics i tried to download them with the phone it must not have worked
Attached Thumbnails Kyosho Ultima RB6 & RB6.6 Car Thread-shock-tool-shock.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-shock-tool.jpg
eper is offline
