Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 11-08-2012, 08:11 PM
  #2476
cnelson3's Avatar
Trader Rating: 66 (100%+)
Originally Posted by MikeR
Hi All,
Bunch of new parts came in as promised.
http://www.exotekracing.com/kyosho/
an aluminum diff nut! amazing!
cnelson3 is offline
Old 11-08-2012, 09:35 PM
  #2477
CanyonCarverR1's Avatar
Hi All,
Any estimate as to when you might get black version in?
CanyonCarverR1 is offline
Old 11-08-2012, 10:51 PM
  #2478
aloksatoor's Avatar
Trader Rating: 43 (100%+)
U can select red or black right now.
aloksatoor is offline
Old 11-08-2012, 11:08 PM
  #2479
K_King's Avatar
Trader Rating: 47 (100%+)
Hi All,
Hey Mike, would you guys sell the actual stand offs for the battery straps? I want some of those right now, but not really the CF strap as it may stiffen up the car a little too much for my liking.
K_King is offline
Old 11-08-2012, 11:12 PM
  #2480
K_King's Avatar
Originally Posted by lagcisco
I only have the stock pistons, 5 hole.
Try losi 55s
K_King is offline
Old 11-09-2012, 12:42 AM
  #2481
37.5wt front, 32.5wt rear is a good starting point with the stock pistons.
Jason.Dias is offline
Old 11-09-2012, 05:43 AM
  #2482
Was wondering if there's any advantage to using an 88 tooth spur gear with a 43 tooth pinion gear instead of a 76 tooth spur gear with a 37 tooth pinion gear. (They both end up being about the same gear ratio.)
Thanks.
Allen
abinder is offline
Old 11-09-2012, 06:22 AM
  #2483
silvalis's Avatar
Trader Rating: 29 (100%+)
Thanks.
Allen
Good luck fitting those in. The biggest I can fit with the stock 76 spur is a 30 or something.
silvalis is offline
Old 11-09-2012, 06:29 AM
  #2484
fastestwon's Avatar
Trader Rating: 15 (94%+)
I can get a 76 / 42 tooth on mine just done some custom work on it is all .
fastestwon is offline
Old 11-09-2012, 07:48 AM
  #2485
Cpt.America's Avatar
Trader Rating: 52 (100%+)
yeah, but why would you cut your car up instead of buy a properly sized spur gear for $5 to get your gearing right? you can buy 75s, 72s, and 69s.
Cpt.America is offline
Old 11-09-2012, 08:00 AM
  #2486
fastestwon's Avatar
i prefer the kyosho gears they work better with the slipper unit . all i do is mod the motor plate back further and down
Old 11-09-2012, 08:48 AM
  #2487
I just wondering because I saw a setup sheet for a RB6 that had 88 spur and 43 pinion on it. (Maybe it was a mistake and meant to be a 88 spur and 33 pinion?)
Allen
abinder is offline
Old 11-09-2012, 08:58 AM
  #2488
fullsyzz's Avatar
Trader Rating: 121 (100%+)
That's probably a 64 pitch setup.
fullsyzz is offline
Old 11-09-2012, 09:02 AM
  #2489
NTR
Allen
Can you link the setup sheet?
NTR is offline
Old 11-09-2012, 10:03 AM
  #2490
wrightcs77's Avatar
Trader Rating: 551 (100%+)
Bigger spur and bigger pinion will move the motor further back, increasing rear weight bias and improving traction........in theory.
Basically taking one of the heaviest parts of the car (the motor) and hanging it further behind the rear axle.
wrightcs77 is offline
