Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 10-15-2012, 12:57 AM
  #1576
silvalis's Avatar
Trader Rating: 29 (100%+)
mm yeah. If your slipper was tight, were you wheelie-ing easily? The GC is indoor clay yeah?
You said you have run the motor previously, but how about the esc? I know that some (ie, this viper I have) are ridiculously slow if you forget to change profiles and leave it in the one labelled "17.5 spec". heh.
silvalis is offline
Old 10-15-2012, 01:01 AM
  #1577
silvalis's Avatar
Originally Posted by v1r killer
I reset my speedy while at track invade that was it, I will pull my slipper down I think and check it , funny thing we had 2 x new buggies each had the same prob on both. I have new pads coming so I might try the new pads and see if thy makes diff. This is my first slipper I have had issues with. Do the pads need to be ruffed up before installing for a bit more grip??
Nah. Run em as is, unless you messed up the initial slipper setting and turned them glassy or so. Even then, for regular use I dont think you would really ever have to change slipper pads.
If your slippers went glassy and it was slipping like crazy, you should be able to hear it as it goes past the driver stand.
One thing I noticed - it's a bit harder to do a wheelie on this car than it was on my stock RB5WC. I suspect it's due to the weight distro and the shorter wheelbase.
silvalis is offline
Old 10-15-2012, 01:08 AM
  #1578
Just came across this video, its hard to see but the car looks pretty good.
http://www.youtube.com/watch?v=7nOuxXJ9Sqw
sdnspecial is offline
Old 10-15-2012, 01:13 AM
  #1579
v1r killer's Avatar
Yes all clay, it is the double single that was easy with the 4.1 is now three singles and I am now loosing time, I can hear the slipper gripping and not buzzing up. It is no where near lifting the front wheels. Diff is tight , I don't normally ask for help but I am a bit lost with this one. I thought my gearing might be the problem but I will re check my slipper again, thanks for the help
v1r killer is offline
Old 10-15-2012, 01:24 AM
  #1580
toast.'s Avatar
Trader Rating: 14 (100%+)
Will both of these work for .5 rear hub carrier upgrade?
STRC .5
Kyosho .5
toast. is offline
Old 10-15-2012, 01:31 AM
  #1581
goBezerk's Avatar
Originally Posted by gas1313
What part in the steering keeps breaking! Just wanting to know before I run! Thanks if possible part # and does the gear diff fit this car.
Yes, the SC-R gear diff will fit no probs as the gearbox is internally the same.
goBezerk is offline
Old 10-15-2012, 01:52 AM
  #1582
jordy-15's Avatar
Trader Rating: 17 (100%+)
STRC .5
Kyosho .5
they are both good but IMO the kyosho is the choice may be 2x the price but you can get the bearings out with no problems.
if you choose the strc version i would suggest smearing the outside bearing race with black grease so you get the bearing out easier
cheers
jordy-15 is offline
Old 10-15-2012, 02:34 AM
  #1583
silvalis's Avatar
the Kyosho also uses a larger outer bearing, which is apparently good.
silvalis is offline
  #1584
OMG23RC's Avatar
Trader Rating: 21 (100%+)
Does the rb6 come in individual parts or is on that plastic tree thing? And if it on the tree do you have to dremel off the little leftover bits?
OMG23RC is offline
Old 10-15-2012, 03:08 AM
  #1585
steam's Avatar
Default tranny
Double check your diff. make sure its installed correctly and on the right side. Male sure the case isn't too tight. The transmission should be free. it's easily over tightened
steam is offline
Old 10-15-2012, 03:20 AM
  #1586
gelshocker's Avatar
Do yourself a favor and get the Tamiya side cutter TAM74035
gelshocker is offline
Old 10-15-2012, 03:55 AM
  #1587
OMG23RC's Avatar
So it does?
OMG23RC is offline
Old 10-15-2012, 04:45 AM
  #1588
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Yes it does, but there usually isn't much in the way of flashing. An Xacto or small file is all you need (and that's if you're anal retentive).
t0p_sh0tta is offline
Old 10-15-2012, 05:07 AM
  #1589
eper's Avatar
id start by recalibrating your esc and a new sensor wire. also may want to check the capacitors on the esc
eper is offline
Old 10-15-2012, 07:08 AM
  #1590
Tech Legend
Trader Rating: 1212 (100%+)
yes the gear diff fits.. its the same ole transmission
bigwavedave33 is offline
