TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 11-13-2012, 03:20 PM
  #4306
spider882009's Avatar
Trader Rating: 7 (89%+)
Still searching for a Mid motor or rear motor setup sheet for a carpet track? Prefer with a Ball Setup. Will be running a 17.5 Viper w/ Viper VTX10 ESC also. We usally run Dynamite Robbers or Street Fighters.
spider882009 is offline
Old 11-13-2012, 06:22 PM
  #4307
vito's Avatar
ok thanks guys i called hh and i got 7 to ten day to get the sway bars from them and call them back by sat. i got a set of rears from a main on order. the just got them in and not have the fronts at the time.
vito is offline
Old 11-13-2012, 06:40 PM
  #4308
vito's Avatar
guys got a pic of this mounted up and what all do i need
http://api.viglink.com/api/click?for...13528607186032
vito is offline
Old 11-13-2012, 06:55 PM
  #4309
stunter38's Avatar
Trader Rating: 73 (100%+)
You have to run ae spurs too.
stunter38 is offline
Old 11-13-2012, 06:57 PM
  #4310
vito's Avatar
i saw that. whats on the back side of it stock losi plates
vito is offline
Old 11-14-2012, 01:39 AM
  #4311
ScottKelly911's Avatar
I listed this setup from an RCT member on the front page under RCTech Member Setups. http://www.rctech.net/forum/attachme...t_20121110.png
Still no "official" TLR setups for mid-motor/carpet yet, but the above setup should be a good jumping off point.
ScottKelly911 is offline
Old 11-14-2012, 03:22 AM
  #4312
Butch Mann's Avatar
Trader Rating: 40 (100%+)
From the transmission out it should be stock Losi plate..AE slipper pad...AE spur gear..VTS assembly outer housing,pad,plate,pad and outer plate then AE spring AE washer and Losi nut. Then I used spacers on the spur gear cover like someone had posted earlier.
Butch Mann is offline
Old 11-14-2012, 06:38 AM
  #4313
Grandturk's Avatar
So has anyone run the associated big bore 2 hole pistons in their TLR shocks? Results?
Grandturk is offline
Old 11-14-2012, 07:15 AM
  #4314
Gas Rat Racin's Avatar
Trader Rating: 37 (100%+)
22SCT Carpet Setup
Front: 40 wt oil, 55 piston, blue spring, no limiters
Outside on arm, middle on tower
1-A camber link, 2mm spacer inside
30 degree kick, 0 deg caster blocks, spindles down
Thickest sway bar
30mm ride height, -1 degree camber, 0 degree toe in
Rear
Mid motor, 3.0 HRC block, 1 degree anti squat
32.5 wt, 55 piston, 3mm limiters, buggy white spring
2nd hole on tower, outside on arm
1-E camber link, 2mm inside, 1mm outside
Hubs middle wheelbase
Stock wheel hex
29mm ride height, -2 degree camber
5000wt dif oil
Battery back against motor guard
Medium sway bar
Kyosho stock front tires, hpi trepador compound d both with proline closed cell inserts
Gas Rat Racin is offline
Old 11-14-2012, 08:47 AM
  #4315
Thumbs up Thank You!!!
Originally Posted by Gas Rat Racin
22SCT Carpet Setup
Thickest sway bar
Rear
Stock wheel hex
5000wt dif oil
Medium sway bar
That is very helpful for me. I was gonna stick with the Ball Diff. My track hooks up pretty good with Slicks and Street Fighters also. But might try them tires to be diff.
Old 11-14-2012, 09:02 AM
  #4316
I am currently using them in my 22t and 22sct. they are very smooth.
No need to drill/file/clean. just simple.
Coolza
Coolza is offline
Old 11-14-2012, 09:15 AM
  #4317
dtr
dtr's Avatar
Do you prep those tires? When I tried them they had no side bite at all, regardless of surface.
dtr is offline
Old 11-14-2012, 09:40 AM
  #4318
22SCT Carpet Setup
Thickest sway bar
Rear
Stock wheel hex
5000wt dif oil
Medium sway bar
Not running any weight anywhere? BTW, just posted your setup on the front page in the RCTech Member setups. Thanks!
Keep em coming guys, if you have a setup that works really well for you but is different than what the Pro's are using, feel free to share them. We still don't really have a good outdoor setup for really loose tracks, so if you have one and would like to share it, feel free to post it and I'll put it on the front page. Please remember to note how much weight your using and where you put it if applicable.
Old 11-14-2012, 10:18 AM
  #4319
When brand new I use paragon before I run and after I clean them with simple green until they break in then I just use simple green it makes them pretty sticky. Depending on traction on each night I may use paragon or simple green or nothing at all.
Old 11-14-2012, 10:22 AM
  #4320
Nope no weight I tried several variations and it just made the car feel too sluggish on our tight tracks, plus there's better ways to get traction then just add weight. BTW I got this setup from another RCTech member I just modified it to add sway bars. I also changed springs and got rid of the giant brass knuckle on the back.
