TLR 22SCT Thread (Check First Page for FAQ & INFO)
#1802
Well I got my first laps with the 22SCT tonight at FZRC in Sarasota Florida. The track had been rained on from Tropical Storm Isaac. The clay was somewhat wet and very loose on top. I had a ton of rooster tail. Was running a blink 13.5 motor.
These are the problems and good things I had with the truck. Stripped out the stock servo horns. Put on a TLR metal servo horn. Ball cups on my truck will be a problem. I ran the fronts cut down and the rears not cut down. A front turn buckle popped off and a rear turn buckle popped off. My SC10 never had problems with turn buckles. These pop offs weren't from hitting pipes either. Just weird landings off jumps.
The truck ran fantastic though. Ran mid motor and kept putting the throttle rate up and up till I hit 150%. Never looped the truck once. I need to work on getting the truck to rotate through the corners and get the front end working better but this is going to be a much better truck than the SC10. Worked very well on a very very loose wet track.
#1805
#1806
#1807
#1808
#1809
I asked a question, those in the know could have just provided a link. Instead you have to go through the old "should have searched BS". You know what, the way the forum is set up, the search function doesn't work. Now if someone was able to make a new thread *GASP* titled "22SCT ball cup trouble" i'm sure EVERYONE would be able to find the answers they needed. But you continue to want us to make 50000 page threads that are completely unsearchable but only for people asking the same questions that may or may not get replied to. But I am the douche, whatever.
once again agreed.
#1810
R/C Tech Elite Member
Have you tried petit rc setup database?
http://www.petitrc.com/reglages/SetupSheetDataBase.htm
For the 22SCT since it is brand new you won't find one on there, there is one on the very first page of this thread though!
#1811
ScottKelly911 as done a awsome job posting most questions and answers on the first post and keeps updating it also with setups and mods and parts updates.
#1812
front page request:
it would be nice to have all of the spring rates/colors (and TLR part numbers) available for the truck. this being my first 22, there seems to be a lot of options with buggy springs, truck springs, etc and people recommending either type.
#1814
Yep the b4.1 diff bolt works no mod you can use all trl tool work too
#1815
TLR5162 1.6 Grey Truck
TLR5165 1.6 Grey
TLR5163 1.8 White Truck
TLR5166 1.8 White
TLR5164 2.0 Yellow Truck
TLR5167 2.0 Yellow
TLR5168 2.3 Pink
TLR5169 2.6 Red
TLR5170 2.9 Orange
TLR5171 3.4 Silver
FRONT Shock Springs
TLR5178 2.3 Pink Truck
TLR5179 2.5 Red Truck
TLR5172 2.5 Red
TLR5180 2.9 Orange Truck
TLR5173 2.9 Orange
TLR5181 3.2 Silver Truck
TLR5174 3.2 Silver
TLR5182 3.5 Green Truck
TLR5175 3.5 Green
TLR5183 3.8 Blue Truck
TLR5176 3.8 Blue
TLR5184 4.1 Black Truck
TLR5177 4.1 Black
I listed the truck ones first on the progression as they are longer and thus will feel softer due to a shorter spring being more progressive.
