SC10 Thread Part 2
#3946
Oh trust me, I have wiggled and jiggled every wire on the thing but can't get it definitely do it if I wiggle one thing a certain way. Thats why I'm so confused, I had loose connections on cars before and they were easy to find by wiggling wires but not in this case.
I swapped out the receiver from the one in my buggy and ran a battery through that and got it to do it with that receiver also so that rules out the receiver being faulty if both receivers do the same thing, right? I'm starting to wonder if theres a bad connection INSIDE my battery. I have been using the same battery since day one and even though it charges fine and I wiggle the battery leads and nothing happens doesn't mean it can't be faulty inside, right? The fact that I can get it to act the same way with two completely seperate motor/esc setups (at least to me) rules out the motor or ESC having a bad connection. And I ruled out the receiver, so the battery is the only thing left.
#3952
Speaking of jc, did you see the new carbon fiber steering brace they are selling? ( I dont know how new they are, I just saw them and the add says new but maybe I was just in the dark)
#3954
scored this on ebay. hopefully I can remove the tires and have a few sets for bashing and racing. I cant use the bearing and pin wheels, I just need to get some hex wheels
http://www.ebay.com/itm/111136492415...84.m1423.l2648
#3955
#3956
#3957
Thanks blitz, good info as usual. Got another quicky for you guys. Im heading to lhs here shortly, im wanting to buy and install the avid shock stand offs. They come in two sizes( basically small and large) which sizes do I need? One of each, two smalls, two large?
#3960
Well I like them because under normal driving circumstances they last very well, and even on my basher they hold up very well, like all ball cups they will eventually wear out, I have had mine on for about a year and they are still very hard to get off if I try to tighten the ball diff so they are not to bad, and they are also only 5$ for all around
24Likes
