SC10 Thread Part 2 >
SC10 Thread Part 2
Like Tree24Likes
SC10 Thread Part 2
Old 03-31-2013 | 07:25 PM
  #3301
platgof's Avatar
I tried some slash rear wheels on my sc10 and they were awesome! The rear end was always hooked up. With these and the weights I should be moving out real good.
platgof is offline
Old 04-01-2013 | 06:43 AM
  #3302
Acill's Avatar
I tried a set of my sons from his old slash with Gridirons on them. They stick out to far to be legal for me, but they do work if you did a hex conversion. I just dont like how far out they stick past my body.
Acill is offline
Old 04-01-2013 | 08:51 AM
  #3303
???E-Racer's Avatar
Racing 2wd and 4wd Corr together here soon. Going to be crazy...
???E-Racer is offline
Old 04-01-2013 | 11:53 AM
  #3304
what is CORR?
shagnat is offline
Old 04-01-2013 | 01:12 PM
  #3305
TomErickson's Avatar
Originally Posted by shagnat
what is CORR?
It is an out-of-date race series in the Midwest called:
Championship Off Road Racing series.
This is the predecessor to the TORC series (Traxxas Off Road Championshio). CORR died like SODA. My father used to race SODA in Class 3 and was champion in 1983.
TomErickson is offline
Old 04-01-2013 | 02:17 PM
  #3306
Suspended
I run slash tires on mine and the wheel width is great against traction roll, because its so wide!!
theblitzkidd is offline
Old 04-01-2013 | 02:25 PM
  #3307
Thanks! That's at least one thing I don't need to worry about.
shagnat is offline
Old 04-01-2013 | 02:35 PM
  #3308
Suspended
Ok I am thinking out loud here, it seems to me that the sc10 is sloppy with rpm on it, I mean like it feels more accurate or controllable with the stock arms, like they rant as flexxy as the rpm ones are!!!
Old 04-01-2013 | 02:39 PM
  #3309
Wildcat1971's Avatar
genius, you mean the unbreakable rpm arms are more flexible than the stock ones. My god, you sure solved that puzzle, lol. The rpm stuff is designed for smashing into objects, not designed for racing.
Wildcat1971 is offline
Old 04-01-2013 | 03:01 PM
  #3310
platgof's Avatar
RPM actually works for racing when you hit as much stuff as I do on the track! ACILL, make sure you use the slash rear wheels, not the fronts. Fronts are too wide.
platgof is offline
Old 04-01-2013 | 06:23 PM
  #3311
Default Servo
Looking to upgrade servo on sc10rs any suggestions it' just feels like it doesn't turn very good around corners we built a 7 ft wide track on 2,200 sq ft
Pointblankya is offline
Old 04-01-2013 | 06:30 PM
  #3312
Pickup a solar 770 from hobbypartz.com
Old 04-01-2013 | 06:31 PM
  #3313
mblgjr's Avatar
Have you glued the servo saver?
Otherwise any servo that has 70 oz/in of torque, or more will suffice.
mblgjr is offline
Old 04-01-2013 | 06:39 PM
  #3314
Glued?? Not very educated on this kind of stuff yet can you explain it to me
Old 04-01-2013 | 07:11 PM
  #3315
Suspended
Well I didn't say they were designed for racing, I just figured they r flexible to the point that u can't race with them, I tried, and it makes my truck way to wobbly.....and I am a genius, don't let anyone else tell u diferent
