Tekno RC EB48 Thread >
Like Tree2Likes
Old 12-30-2013 | 08:28 PM
  #10471
Mizchief's Avatar
Originally Posted by FastPete
Don't want to start a war here I have a aluminum servo horn coming. But will the stock one be ok installed tight and properly?
Unless they have been updated since the SCT410 I wouldn't expect it to last past a couple of packs at race speed
Mizchief is offline
Old 12-30-2013 | 08:36 PM
  #10472
BLbound's Avatar
Originally Posted by 8ight-e
Ok couple quickies.. putting the kit together.. not going as smooth as many others but not awful either. I must say the diff spacers in this design are a pain, but small thing.. the real issue is the arms, they should be free flowing but with a 3.5 toe setup they are locked up pretty good.. do I remove a little material or am I missing something? Is there no way to get a 3' toe? What are the inserts w/ the two dots vs the one, the manual only seems to show setups w/ the single dot on them? I also see why people say keep extra a-arms these plastics are def a different material than many other manu's.
As far as getting the arms to be free, I used a Hudy arm reamer, it worked flawlessly, no issues.
BLbound is offline
Old 12-30-2013 | 08:55 PM
  #10473
Rockthecatbox21's Avatar
Ok couple quickies.. putting the kit together.. not going as smooth as many others but not awful either. I must say the diff spacers in this design are a pain, but small thing.. the real issue is the arms, they should be free flowing but with a 3.5 toe setup they are locked up pretty good.. do I remove a little material or am I missing something? Is there no way to get a 3' toe? What are the inserts w/ the two dots vs the one, the manual only seems to show setups w/ the single dot on them? I also see why people say keep extra a-arms[B] these plastics are def a different material than many other manu's.
Yeah, they're not all flexy and warped like losi's.
Rockthecatbox21 is offline
Old 12-30-2013 | 11:29 PM
  #10474
8ight-e's Avatar
now now :P a slight warp vs a DNF? Let's hope it doesn't come to that though 90% done w/ the build. Bed for now..
8ight-e is offline
Old 12-31-2013 | 12:12 AM
  #10475
BLbound's Avatar
Ya, my buddy who just came from a Kyosho mp9 tkii to a losi 3.0e mentioned the difference in plastic, the Losi a-arm plastic is way flexy in comparison to Kyosho & Tekno.
BLbound is offline
Old 12-31-2013 | 12:46 PM
  #10476
8ight-e's Avatar
Anyone running 6s lipo w/ the tekin 1400kv motor? Just looking for a gearing start point. TY What is everyone running w/ 4s 1900kv setups?
8ight-e is offline
Old 12-31-2013 | 01:12 PM
  #10477
UK.hardcore's Avatar
18T.
UK.hardcore is offline
Old 12-31-2013 | 02:23 PM
  #10478
Im running a 19t for my 1900
micrors4guy is offline
Old 12-31-2013 | 02:48 PM
  #10479
Guest
Default hello guys
Hello guys!!! My name is sidney tripp an I am addicted to Rc racing.
And my 6yr son is just starting too.
I just ordered my tekno eb48.2 . Is there any building tips to look at? Diff oils? I did race kyosho buggy so I do have the springs and 1.3 x 8 pistons all ready. I have seen these buggy in action and take a lot of beatings so parts will be basic and understood. Arms -shock shafts - graphite towers only cause I like the carbon.and drive shafts. And spur. And bearings. Extra body.and the alum hinge pin mounts. What else would u all buy?
kyoshoracer77 is offline
Old 12-31-2013 | 03:09 PM
  #10480
8ight-e's Avatar
Originally Posted by UK.hardcore
18T.
Thanks.. I'll start w/ 16t and go from there.. my setup rpm is a touch higher w/ 1400kv on 6s.
8ight-e is offline
Old 12-31-2013 | 03:15 PM
  #10481
Im running a Tekin 1400kv with Eco 6s packs. Currently running a 17t pinion.
BJT2814 is offline
Old 12-31-2013 | 04:02 PM
  #10482
Post
Save on the aluminum mounts and carry a spare front shock tower. I see you are getting the carbon one so keep the stock one on hand. Also a wing mount.
Old 12-31-2013 | 05:58 PM
  #10483
justpoet's Avatar
As ebuggy lite is trying to take off, does anybody make (or Tekno plan to make) a front shock/tower guard? This would both protect carbon towers if used, but also help protect the track from digging the towers into indoor dirt that probably isn't used to ebuggy towers.
Also, is there a thread I'm missing that is dedicated to the eb48 lite setups?
justpoet is offline
Old 12-31-2013 | 06:07 PM
  #10484
What are you considering a super light? Im about 80grams over min weight with a steel spurr. Remove that and throw some ti turnbuckles and I would be at minimum weight. Also my bce chassisjust came back so that is another few grams removed.
I have a old viper 4.5 sc motor I could throw in with a 2s to try but my buggy has been reall good in the current form.
Old 12-31-2013 | 06:25 PM
  #10485
justpoet's Avatar
The current spec I've seen thrown around is 3200g as max weight and many places still require 2s. That's a bit above an eb48 weight on 2s, and well above a converted sct410 with a light chassis. The class is still in the forming stages though.
justpoet is offline
