Tekno RC EB48 Thread >
Like Tree2Likes
Old 09-16-2013 | 06:35 PM
  #9181
Mason Eppley's Avatar
Is it a good idea to use green slime in my shocks or not to?
Mason Eppley is offline
Old 09-16-2013 | 06:37 PM
  #9182
RazzBarlow7's Avatar
Definitely a good idea. Lowers your chances of damaging an O-ring during assembly for sure.
RazzBarlow7 is offline
Old 09-16-2013 | 06:48 PM
  #9183
And also I'm having major problems with my all my shocks and center diff leaking. What could solve and help me with this problem.
Old 09-16-2013 | 07:25 PM
  #9184
Graham11's Avatar
Originally Posted by mourinho
Hey roklem, where do you get those blue washers that you have under the servo mount screws?
Any hobby site has them just search blue countersunk on amain
Graham11 is offline
Old 09-16-2013 | 08:03 PM
  #9185
LAZNICK RC's Avatar
Smile
Always a good idea to lube orings and its seating position in diff . Insert orings carefully and make sure they are seated correctly. Lube outdrives shafts this will ptevent tearing when inserting through orings.
Lube gasket both sides to create good seal .all lubing use the same silicon oil as in the diff this will prevent any contamination and you are using same product as what you trying to seal against.
Fill diff to top of spider gears if you want consistency weigh diffs before filling then fill one weigh again and apply this method to other diffs. they should all be close in weight in amount of fluid in them . Move spider gears to settle fluid remove all air bubbles.Apply gasket , line up holes with diff cup.place two tooth pick through to opposite holes .
Slide ring gear over tooth picks this will line up ring gear with holes on diff cup with minimal movement of gasket. Apply two screw then other two remove picks first.
Tighten down in a cross pattern all the way down firm once all screws are down torque them by giving each screw half to one full turn each . See how you go with my ideas hope it helps buddy
LAZNICK RC is offline
Old 09-16-2013 | 08:25 PM
  #9186
Thanks I really appreciate it.
Old 09-17-2013 | 05:07 AM
  #9187
snwchris's Avatar
Here's a couple pics of my recent EB48.2 build, this weekend will be hitting the track to work on setup and hopefully have the body back from painting later this week or next week.
The HW150A ESC is definitely a snug fit with not alot of room left over. I use the Kyosho Zeal Adhesive pad for the ESC, cause once it sticks down it doesn't move.
Hopfeully next week, should have a new servo as well for it, going with Hitech 7945 (0.10/320)
Attached Thumbnails Tekno RC EB48 Thread-rmr-tekno-5.jpg   Tekno RC EB48 Thread-rmr-tekno-6.jpg   Tekno RC EB48 Thread-rmr-tekno-7.jpg
snwchris is offline
Old 09-17-2013 | 05:39 AM
  #9188
Genebaby's Avatar
Nice! Good luck with it at the track.
I found out recently that the only difference between the SCT Pro (120A) and the 150A HW ESC's is that the SCT Pro can't do past 4S.
I'm giving an SCT Pro a try in my upcoming Tekno V4 conversion of my Vorza.
Genebaby is offline
Old 09-17-2013 | 05:55 AM
  #9189
Thumbs up
Try shoegoo! Works great and removes with no mess.
2SlowTC is offline
Old 09-17-2013 | 06:05 AM
  #9190
snwchris's Avatar
Yea but with shoegoo, there's no padding for any hard impacts, with the Zeal Pad, its a gel antivibration pad and soaks up any hard landings that the ESC might see.
I run 4s only, so I'm thinking maybe next month switch over to the SCTPro 120A.
snwchris is offline
Old 09-17-2013 | 06:13 AM
  #9191
Motorman007's Avatar
Great stuff I like this PHAT PAD...
Motorman007 is offline
Old 09-17-2013 | 06:22 AM
  #9192
Originally Posted by RokleM
I noticed a distinct lack of pictures in this thread recently, so let's post up a few if you have some. Specifically I was looking for some new mounting/wiring locations and didn't have much luck. This is useful for the guys/gals building the new kits (especially since the EB48.2 is out).
Got tired of the excessive heat, wiring problems (pre-installed wires can't be removed from motor), and broken fans. So sorry hobbywing, you're my secondary now (still primary in the SCT410).
These are some great plugs
http://www.hobbyking.com/hobbyking/s..._5_pairs_.html
for the Battery
https://www.facebook.com/pages/SUPRA...40794192693371
+ YouTube Video
+ YouTube Video
Old 09-17-2013 | 06:42 AM
  #9193
Genebaby's Avatar
I just ordered some sets of the motor plugs from Hobbyking today for my cars.
I am happy with EC5's for the battery, but they look nice as well.
Genebaby is offline
Old 09-18-2013 | 04:05 PM
  #9194
bcjoldbq's Avatar
JQ Products has those washers for flathead screws in M3 and M4 sizes for their 8th scale rigs. They come in blue and I think red and gold too.
bcjoldbq is offline
Old 09-18-2013 | 05:45 PM
  #9195
Got my buggy painted tonight!! My esc , servo,motor, and batteries showed up today! I cant wait to get it all together.
mxarcher is offline
