Tekno RC EB48 Thread >
Like Tree2Likes
Old 04-30-2012, 01:57 AM
  #46
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Originally Posted by thecman26
Take a look at the picture, behind the battery is a mounting point for a brake servo, just add a diff center diff mount, throw on discs, and brake cams. Bam ya got brakes!
Take a look at my original post. My question is regarding the clearance for the brake discs and calipers.
Dan is offline
Old 04-30-2012, 02:07 AM
  #47
UK.hardcore's Avatar
my guess, the calipers go on the left side and they use a very small front disc.
UK.hardcore is offline
  #48
BLbound's Avatar
Trader Rating: 27 (100%+)
I think this buggy will be out before the duratrax dxr8e!
BLbound is offline
Old 04-30-2012, 08:40 AM
  #49
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Originally Posted by Dan
Got a question, how will the layout look like with the mech brakes? I noticed you guys have gone for a key/slot motor mount and I believe this may interfere with the front/rear brake discs if there were to be mech brakes.
The previous Tekno conversions used a longshank pinion for clearance.
Yup, from what I understand, the center diff gets flipped 180 degrees. You use a longshank pinion. Install servo and brake hardware and you're good to go.
SEF is offline
Old 04-30-2012, 09:07 AM
  #50
teknorc's Avatar
Hi guys,
Thanks for the interest. Keep the questions coming, we'll answer everything we can.
So, for mechanical brakes, we designed a completely new system.
There is NO need for a long shank pinion for any reason on this buggy.
The brake pads and levers are on the left side of the diff mounted vertically, the discs slip in on either side of the diff. There are no clearance issues, we made sure of that during design and testing. You can't see unless you take it apart, but there is a big cutout on the motor mount insert for front disc clearance, it's pretty slick.
You can flip the diff 180 so the gear is in back, but that doesn't affect the brakes. You flip the diff for Traktion Drive or Elektri-Clutch use. So you can use mechanical brakes with standard pinion, TD, or EC. The motor stays in the same position for all options.
teknorc is offline
Old 04-30-2012, 09:09 AM
  #51
teknorc's Avatar
Originally Posted by NitroOB4You
Plastic spur? Please, at the least make an aftermarket metal gear available. Yeah, I'm probably in the minority I know. But I will buy if you make it
We got you covered. There will be a steel option at or soon after launch. We recommend the steel spur for Traktion Drive or Elektri-Clutch use. If you're going direct drive, the plastic spur holds up well.
teknorc is offline
Old 04-30-2012, 09:10 AM
  #52
teknorc's Avatar
Originally Posted by hlpressley
Hope we can find a super short sensor wire.
They sell them really short. The wiring is extremely tidy on this thing.
teknorc is offline
Old 04-30-2012, 09:11 AM
  #53
Is there gonna be a Tekno Truggy?
how big is the battery space?
Old 04-30-2012, 09:17 AM
  #54
teknorc's Avatar
We'll see where the market takes us. There is plenty of room for the longer truggy motors in the buggy, we made sure just in case we ever wanted to make one we wouldn't have to redesign the whole thing .
The battery tray is 50x150mm so you can move a standard 4s pack forward or backward ~10mm.
teknorc is offline
Old 04-30-2012, 09:26 AM
  #55
Trader Rating: 37 (97%+)
Well i was in the market for an e truggy but after seeing this im having second thoughts..
charlesandstuff is offline
Old 04-30-2012, 09:39 AM
  #56
really nice buggy.......good job TEKNO~~~
just wonder the weight compare with D8 V4.
Marco926 is offline
  #57
snwchris's Avatar
Hmmmm what to do, what to do.... I'm on the verge of ordering the V4 chassis for my D8, but dam this thing looks frickin sweet!!!
So this won't be out until summer... is that June, July or August.... if only June, then maybe worth the wait.
snwchris is offline
Old 04-30-2012, 09:46 AM
  #58
teknorc's Avatar
We can't say 100% right now. Manufacturing a whole car is tricky and delays are common. That said, everything is in production and we're on schedule for a late June, early July release as of today.
teknorc is offline
Old 04-30-2012, 09:50 AM
  #59
snwchris's Avatar
Guess I'll have to keep an eye on this thread for any annoucements about pricing and pre-orders then... lol
snwchris is offline
Old 04-30-2012, 09:52 AM
  #60
kufman's Avatar
Looks pretty slick!! How big is the spur and what is the diff ratio? 3.3?
kufman is offline
