Tekno RC EB48 Thread >
Like Tree2Likes
Old 03-14-2013, 08:21 AM
  #5251
Originally Posted by slow_jun
should be filed down and leave no trace of excess material, else that will cause some leaking issues on your shocks.
Keep in mind that these are mass produced injection molded parts. The area that you are looking at is the gate that fills the cavity with plastic, they usually place the gate on the top or bottom of the piston so the complete diameter is round and you do not need to file anything. I don't recall if Tekno did this to their pistons.
jpas is offline
Old 03-14-2013, 08:24 AM
  #5252
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Slotmachine
I have a tip on the shock pistons for you. After cutting them off the parts tree use fingernail clippers to shape the piston where it was taken off the tree, then use a drill (not a Dremel / they spin too fast and will melt the plastic) and spin the shaft and piston and hold some green scotch-brite on the edge of the piston to polish them. This trick will make the pistons very smooth.Don't use sandpaper, it will remove too much material.
Paul Rush
Oh my gosh, i thought i was the only one! I used the file part of the fingernail clippers to file down the burrs on my pistons. I thought it was really ghetto at the time, but apparently it worked great, no leaks, and shocks feel smooth. I guess being a little cheap pays off sometimes. I will say, after i "sanded" them down with the nail file, the part where the burr was ended up being very smooth. Good tip.
Rockthecatbox21 is offline
Old 03-14-2013, 08:26 AM
  #5253
Originally Posted by mdwalsh
titanium is more brittle than steel. it would snap even easier than the steel ones.
Matt
Titanium is not more brittle than steel, it is far more ductile than most steels and also has a much lower tensile strength. Ti is a poor material choice for a hinge pin on an 1/8 scale buggy.
jpas is offline
Old 03-14-2013, 08:34 AM
  #5254
mdwalsh's Avatar
Trader Rating: 29 (97%+)
yeah........ im going to disagree with you on that first part. my personal experiences with titanium and my materials science text book says otherwise.. not starting anything here just dont want to spread misinformation.
Matt
mdwalsh is offline
Old 03-14-2013, 08:42 AM
  #5255
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
Guys , there are several grades/alloys of Titanium some are much more malleable/ductile than steel and are used for their 'memory" (meaning it will bend/flex a whole bunch but return back to its original shape.) others are quite hard and used on high stress areas .
If we are talking in their raw states then yes steel is harder than titanium ....
BashemSmashem is offline
Old 03-14-2013, 08:53 AM
  #5256
Trader Rating: 21 (100%+)
Anyone else have issues with the battery straps ripping? I had one fail after being in there since the car was new. I just thought is was a fluke until my replacement ripped after two weekends of running.
MX304 is offline
Old 03-14-2013, 08:56 AM
  #5257
Check and see if you have a burr somewhere that is cutting into the strap , also make sure the driveshaft doesn't rub on it and they are facing the right way .
Old 03-14-2013, 08:58 AM
  #5258
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
I have had that happen on a conversion. I know someone who put a bit of liquid electric tape on the openings the straps go through to give it more slide. I think with how hard we pull these tight, they are getting cut.
Cain is offline
Old 03-14-2013, 12:14 PM
  #5259
Genebaby's Avatar
Originally Posted by Ryan_in_Az
Run 0 rebound. The springs take care of the rebound.
Thanks, I'll do that. Zero is easy to set!
Genebaby is offline
Old 03-14-2013, 12:17 PM
  #5260
Genebaby's Avatar
Paul Rush
Thanks, I never would have thought go that!
Genebaby is offline
Old 03-14-2013, 12:24 PM
  #5261
Ryan_in_Az's Avatar
They are just like the Losi straps which are just like the straps in my helicopter. Bottom line, they all break and fray. Usually for me they will come apart where the machine thermally welds them together. Best replacement I've found is to use plain Velcro straps without the buckle part. They work way better.
Ryan_in_Az is offline
Old 03-14-2013, 02:57 PM
  #5262
brian94066's Avatar
Check out Scorpion battery straps, I use these in my helicopters and they're really durable since they're quite thick, and are also antislip
http://www.amainhobbies.com/index.ph...filter_mfr=267
brian94066 is offline
Old 03-14-2013, 06:09 PM
  #5263
Genebaby's Avatar
They look pretty nice. Any idea what size to use for the EB48?
Genebaby is offline
Old 03-14-2013, 08:04 PM
  #5264
Not sure if this has been posted but this would have been an awesome race to see!
Mazzara, Anthony 1 1 27 10:00.686 21.284 21.544 21.755 21.991 1
Arnold, Geoff 2 4 27 10:19.496 21.728 18.810 21.977 22.144 22.504 4
This is a new Losi 3.0 Buggy vs the Tekno.
cryofix is offline
Old 03-14-2013, 09:14 PM
  #5265
brian94066's Avatar
I think 2 of the smalls and 1 of the medium would suffice
