Tekno RC EB48 Thread >
Like Tree2Likes
Old 03-10-2013 | 09:58 AM
  #5206
What do guys recommend for improving acceleration to clear triples? I have 7,7,5 in the diffs. The rest of the setup is stock. I tried 10k in the center and it helped, but it is not at the same level of others at the track.
I am running a 1950kv motor with a 16tooth pinion and have plenty of power, I wonder if I should go down to a 14 or 15 tooth.
jpas is offline
Old 03-10-2013 | 10:12 AM
  #5207
patrick lsp's Avatar
tires and a smoooooth throttle finger. more than likely you are spinning all the way up the aproach.
patrick lsp is offline
Old 03-10-2013 | 11:37 AM
  #5208
GrimReminder's Avatar
Originally Posted by subaru_tech
wasnt a fan either.but for my old eyes the contrast with pink/black helps.
I'm gonna have to agree with you.....Pink is starting to grow on me when it comes to R/C Bodies in general. That's a wicked paint job too!
GrimReminder is offline
Old 03-10-2013 | 11:55 AM
  #5209
Originally Posted by Slotmachine
They do have an effect, they allow the steering to travel further without rubbing the back of the wheel.
i turned it lock to lock and seems like there would be plenty of clearance with this particular setup, i do see what you are saying though, thanks.
nitrobandit is offline
Old 03-10-2013 | 12:29 PM
  #5210
any loose track setups? about everything i have found is med bite. its a med size indoor
track that is usually slick. first outing with car not too fun. right now car is built to spec per manual. 7 5 3 and 450/350 in shocks. i did change antisquat to middle and shortened front camber links. also flipped pivot ball on knuckles. i was running near new ss megabytes. that is what most fast guys run on this track. i am in the end of video red body white wheels. just have to crawl thru corners otherwise rear end comes right around. any help is appreciated.
http://www.youtube.com/watch?v=Nfd4x...ature=youtu.be
Old 03-10-2013 | 01:31 PM
  #5211
Slotmachine's Avatar
Smaller rear sway bar for more side bite, no anti-sguat and move the rear hubs forward...........
Paul Rush
HWNA
Tekno
Slotmachine is offline
Old 03-10-2013 | 01:55 PM
  #5212
I have plenty of grip, the approach is certainly a big factor. I will try to reducer my RX8 limiter and see if that helps.
jpas is offline
Old 03-10-2013 | 05:55 PM
  #5213
brian94066's Avatar
Quick rattle can paint job
brian94066 is offline
Old 03-10-2013 | 06:58 PM
  #5214
Afun's Avatar
I put the Austin Blair set up on the Tekno this weekend. Not so good for me. I am sure it could work in some places. I felt the buggy was very lazy for my driving style. Going back to that outdoor set up on the Tekno website.
Afun is offline
Old 03-10-2013 | 08:36 PM
  #5215
Patrick the setup I gave you is what I used at the last points race and won with. Other than testing some pistons it is the setup I'm going to start with this Friday. Try all the changes and let me know if it helps.
sstoffer is offline
Old 03-10-2013 | 09:13 PM
  #5216
mdwalsh's Avatar
does anyone know of any other shock o-rings that would fit, maybe even some that have a little less friction? i was thinking the kyosho x rings ones but im not sure.
Matt
mdwalsh is offline
Old 03-11-2013 | 06:58 AM
  #5217
Ryan_in_Az's Avatar
I just finished building my first Tekno buggy. After buying the SCT-410 and being sooooooo impressed with it, I just had to get this. I can't wait till practice on Wednesday to break it in.
Ryan_in_Az is offline
Old 03-11-2013 | 11:44 AM
  #5218
ChrisAttebery's Avatar
I'm glad you like them.
Originally Posted by beaven
hey chris,just got my shock tools,most impressive,thanks for the great service...might have to break down the shocks on both my teknos just to try them out!!!
ChrisAttebery is offline
Old 03-11-2013 | 12:41 PM
  #5219
BashemSmashem's Avatar
Just bought my shock tools !
BashemSmashem is offline
Old 03-11-2013 | 02:15 PM
  #5220
justpoet's Avatar
Originally Posted by jacked103
had my first broken part today. and iv had it since the end of last summer
That's the original Ackerman Bar. The newer one is beefier and reinforced in the spot that broke. Same part number. Only the original batch had the one pictured, all others since have the more heavy duty one.
justpoet is offline
